Home > Tdi > Cambelt Pulley System issues?? |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Hi folk ... Still working on and learning about my newly acquired 1994 Defender 90 TDi300.
Today I was flicking through a book called "You & your Land Rover Ninety, One Ten and Defender" by Martin Hodder and I came across this comment on page 115 (See top right of picture): Click image to enlarge So what's is the modification? ... and how do I know if I'm pre mod of post mod please?? Cambelt last changed in 2011 at 126,000 miles ... now 156K Thanks all John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Jan 2022 5:10pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
IIRC the bottom pulley used to fail / fall apart with belt shredding results - again from memory there was a bottom pulley supplied with the better cam belt kits.
Hth Keith |
14th Jan 2022 6:47pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3218 |
https://www.lrworkshop.com/blog/300tdi-replace-timing-belt 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
14th Jan 2022 7:10pm |
Ickle, Mossberg and Dinnu - Thank you so VERY MUCH for the prompt and excellent answers! ... REALLY appreciated.
All I've got to do is find out what pulley is fitted! Although the last cambelt was changed ten years ago the Defender has only done 30K, what's your thoughts / advice? Gut feeling are that because its been 10 years, change it (and get the pulley checked) but of course its £££ and I've got the beast booked in for new sills to be fitted next month £££ As always your advise/comments are greatly welcomed. Thank you and have a good weekend! John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Jan 2022 8:50pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 552 |
Get the cambelt done - definitely. I think the maximum time between changes is 7 years.
14th Jan 2022 8:53pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 603 |
If not already fitted you also need to change the injector pump bracket for the revised one that prevents the timing cover moving out of position. Probably only a quarter of the 20+ 300tdi’s that I have owned over the years have had the revised bracket fitted.
You may find that once the revised bracket is fitted, you might have to renew the injector pump head O ring as the reposition of the fuel pump in the correct place by the bracket can cause it to leak if the timing cover has previously been sat out of position slightly. There was supposed to be a yellow square painted on timing cover if all modifications were done but again in over 20 300tdi’s I have never seen a yellow square! Whoever fits the kit also needs a MHH Torqueleader to do it properly. Many so called specialists don’t have one. Last edited by Oldowner on 14th Jan 2022 10:15pm. Edited 1 time in total |
14th Jan 2022 10:11pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 510 |
Old, do you have a picture of the bracket, so I can check if its fitted on mine.
Thanks |
14th Jan 2022 10:13pm |
It is err6835
14th Jan 2022 10:16pm |
Thanks Oldowner - appreciated as always. John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Jan 2022 11:23pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 772 |
An alternative POV to the modification bracket saga is that if your vehicle has got to this point without shedding a belt and the belts are coming off in reasonable condition at replacement time then your engine probably doesn't require the mod.
15th Jan 2022 9:28am |
Hi OS ... Certainly your POV is well worth considering: Appreciate your input
15th Jan 2022 6:50pm |
The other view is a broken Cambelt will always happen at the most inconvenient time and then the cost will be eye watering.......
15th Jan 2022 8:56pm |
Well, after this discussion I've just got my Defender back after having the Cam belt changed and three pulleys. The workshop looked at getting a genuine fuel pump bracket (over £100) too, but after some thought got an "After market" bracket at half the cost. Sadly upon arrival one of the holes was over 5mm out and was not worth fitting. Given the condition of the original cam belt (10 years old) the decision was to use / keep the original one. Now much happier and job done knowing I've got the correct pulleys and a new belt Another fault fixed Thanks for all your inputs 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
9th Feb 2022 11:13pm |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 |
Bit of a topic resurrection, however currently in the process of getting my 300tdi back on the road after a messy breakup. Cambelt snapped while trying to get it away from the ex so she couldn’t set it on fire I’ve got the improved kit and ordered a bracket, what else is required? I did the belt about 6k ago but it snapped very prematurely, so my guess is I missed something last time. |
18th May 2022 10:48am |
