Home > In Car Electronics > If you have an Amp in your Defender where is it?
Stacey007
Hello
I was messing about with my system over the weekend as thought I had damaged my head unit seems to be the amp..
Now its probably a 25 year old maybe more Rockford Fostage unit but alas being kept in a garage for many years then being used I think something has gone 'pop'
Its currently installed in the battery box in void on the other side of the battery. I have a fan (15cm computer fan) keeping it cool and its worked perfectly for two summers so must be cool enough?
Anyway I'm looking at a replacement and maybe even a second amp just for the Sub, so Was thinking where else. I like it hidden so no harm of catching wires when I' m camping or throwing stuff in the car for the tip run.
In the battery box isn't bad but two would be a push, curious where you may put yours?
Post #934393 20th Dec 2021 4:26pm
barbel jim
If you go for a digital amp they don’t really get hot. Cost more but also smaller as a rule. I have mine on the bulkhead behind the seats, but that won’t work for you. The alternative is make your own sub enclosure and put it on the back ??
Post #934445 20th Dec 2021 8:56pm
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Not got an amp yet, but I too was going to place in the battery box under the passenger seat. Seems an ideal place out of the way.
Post #934695 22nd Dec 2021 5:05pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Mine will be in the seat box not decided yet with battery or with the fuses Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #934706 22nd Dec 2021 6:19pm
MichaelE
Depending on what you have under your driver's seat you could put it there with a bit of work. I manufactured a sunken box to put my sub in. My tank is under this seat so it was a bit tight but it fitted perfectly. If you don't have a tank then there could potentially be lots of space.
Post #934712 22nd Dec 2021 6:52pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
Lots of excellent 4 channel amps around. Some even allow bridging two channels to power a sub. probably have a smaller footprint than an older Rockford. 2011 130 Utility Body
2005 110 Van
Post #934717 22nd Dec 2021 7:19pm
Likeomg
I have a hertz Hdp4 and HDP1 both either side of the sub in the boot. hdp1 powering a HX380D sub, and the HDP4 doing all 4 speakers.
Post #934732 22nd Dec 2021 8:36pm
landy andy
If anybody wants a Hetz HE4 amp, and also a sub in a box let me know, as I’ve got both that I’m fed up with taking room up in the garage. Can’t be arssed to post, so collect only. If not will end up in the bin.
Post #934735 22nd Dec 2021 8:53pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
On the lower part on the bulkhead behind the seats for me. I used to have it in the battery box but I did get concerned about water ingress etc. I used to have a budget alpine amp but switched to an alpine pdx-v9 and it’s simply incredible the difference. I can’t recommend it enough, it probably one of the best sound systems I’ve ever heard now. Will have to try and get a picture for you.
Post #938732 21st Jan 2022 9:15pm
PCM
Battery box every time for me
Post #938858 22nd Jan 2022 5:28pm
bankz5152
In my 110 DCPU its mounted on the rear bulkhead behind the rear seats.
In my 90, bulkhead behind the seats.
Mate of mine used a cubby lock and mounted it under the cubby box. Instagram @defender_ventures
Empire Tuning - Agent
Post #938872 22nd Jan 2022 6:33pm
I built a wooden box up in the back of the roof (done this on the past few defenders I've had), full width of the roof, following the profile of it, and qbout 12" deep. Into which are a pair of trusty 6x9's, so a nice bass box if you will.
Inside this box I've also got a couple of amps mounted (one for the 6x9s and another for the bass unit mounted on the back floor)
probably not to everyones taste as it takes up valuable room in the back, but mine only carries off road kit and a second spare wheel in the back, so no issue there.
Does sound good mind!
Post #939126 24th Jan 2022 7:05am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Mine lives in the electrical department below the driver's seat, beneath the rail that holds the ECU (Td5).
Post #939148 24th Jan 2022 10:49am
d-digby
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Same here, under the drivers seat
Post #939155 24th Jan 2022 11:18am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I have what I think is the simplest and smallest (in size) power Amp available on the market: the Alpine KTP-445A. I have it hidden directly inside the dash, secured in a recess.
https://www.alpine.co.uk/p/Products/SingleView/KTP-445A
I inititially installed it as a temporary-cheap solution to drive new Focal ES100K (front) and PC130 (rear) untill I decide on a bigger amp setup and location. That was 3 years ago. Happy with it so far, does the job and what it says on the box, and I don't plan to upgrade it in a near future.
/Mat
Post #939340 25th Jan 2022 8:25am
