Home > Technical > Number plate light/bulb |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19638 |
Corroded connectors possibly, Iβd suggest a Wipac LED replacement unit.
The factory number plate light suffers with a lot of corrosion related issues. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
5th Dec 2021 6:58pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 769 |
Is this the standard Landrover light fitting? There should be two small bulbs and it is always worth checking the lens is clean as these often get gunked up with mud and moss as the fitting is poor and rarely watertight. If all is present and correct the lamp should illuminate adequately.
5th Dec 2021 6:59pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Thank you both, this is the standard Land Rover, it only has one light bulb, not 2.
Steve do you have a link for the Wipac led replacement? FΓ‘bio |
5th Dec 2021 7:40pm |
https://www.ebay.co.uk/itm/373722175909?fi...Swsk9helvw
This particular one is good, straight fit no mods needed except for wiring connections. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
5th Dec 2021 7:54pm |
Thank you Steve!
5th Dec 2021 9:05pm |
ππ» Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§
5th Dec 2021 9:38pm |
