Home > Tdi > Permanet live - Simple for some - Not for me! |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Hi folk
My newly fitted radio keeps dumping its setting and has become a PITA to keep re-setting. I've now learned that the radio's memory needs a permanent power source ... so my radio is in the area above the cigarette lighter / rear wiper switch. Can anyone please tell me where I can pick up a constant rather than switched live please. MTIA John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
13th Nov 2021 8:22pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Hazard light feed i think that's permanent live.
13th Nov 2021 10:00pm |
Thanks Nitram - Sounds a good starting place for tomorrow
14th Nov 2021 1:02am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3219 |
I managed to find the below schematic for a MY97.
The memory supply to the radio, permanent feed, the wire is purple and is through Fuse 2 (which is the same fuse as the interior light). The switchable power supply, which is what you already have is through Fuse 7, and wire colour is white/red. Ensure that you have both switching supply and permanent feed to the radio. This way the radio switches off when you switch off from the ignition key, but keep a very small amount to power to the radio for memory purpose. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Nov 2021 4:40am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
On my 300Tdi with a Pioneer radio I had the same problem and the solution was to just swap the 2 input wires around. Not sure where I got the informatiin from but the saved settings were not dumped. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
14th Nov 2021 10:07am |
Morning Dinnu - Thank you very much for the two posts and diagram - much appreciated! Hopefully that will sort my issue out, just got to wait for it to stop raining! ATB John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Nov 2021 10:23am |
Thanks Jeffers - appreciate the information too. John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Nov 2021 10:25am |
Check the radio. But most will have a red and yellow wire.
Usually the red will connect to white/red on the landy and yellow connects to purple. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Nov 2021 11:23am |
Thank you very much to all who replied - GREATLY appreciated!
Purple wire found and connected to the yellow of the radio - all settings now being held in the memory ... next job ... 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Nov 2021 2:26pm |
