Home > My Defender > 1989 Ninety CSW - Update: 8 cylinders
Page 14 of 19 <123 ... 131415 ... 171819>
Procta
someone needs to watch Mark Evans 4x4 is born Very Happy
Great upgrade there, such a shame things went bang on you, but at least you decided to keep it as a toy. you can really go to town now! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #926303 19th Oct 2021 5:50am
Pickles
A 5 or 600 Holley with a cam, a bit of headwork & some pipes would work wonders for that engine.
"Nothing like a V8", as we say in Aussie, good luck with your "re-power", I shall be watching your progress with interest, & guarantee that upon the first drive with 8 cylinders, an unpreventable smile will appear upon your face!
Pickles.
Post #926442 19th Oct 2021 10:43pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Another weekend, another update Very Happy
Finished up the block cleaning and installed new core plugs:
Then put the crankshaft in with new shells and rear seal, all installed with assembly lube. Then the arduous task of cleaning up the pistons, installing the new rings and big end bearings before spending half an hour per cylinder cursing profusely at those poxy piston ring compressors Laughing
Next up: the camshaft. Quite surprised the valves even opened on the old cam looking at the state of the lobes Laughing
Setting the timing - ridiculously easy on these engines, I assumed I must be missing something
Finally, spent some time cleaning up the sump and giving it a quick lick of paint.
Looking to get the timing cover and mating faces cleaned up this week, then get the sump on and can start thinking about the top end. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #927106 25th Oct 2021 8:41pm
trickster5000
Another long overdue update...
Engine refurb is complete bar the Edelbrock carb and manifold which I have but still need to fit. Spent a little while tarting up the rocker covers:
Attention then turned to the old chassis/running gear - I've gone down a bit of an unorthodox rebuild route simply because of space/current living arrangements which means I started with a double axle amputation as below:
Which I've since stripped and rebuilt, many hours with a wire wheel but no real issues:
My new Shielder V8 chassis has also arrived recently, great service again from them
Also some shine new bits from Ashcroft - a new R380 and LT230 with a V8 bellhousing, not a cheap trip Embarassed
The plan now is to get this all home, bolt my shiny new axles to my shiny new chassis (once painted) and then chuck the engine and gearbox on for a full rolling chassis. Then just the simple task of transposing the bodywork from one chassis to the other... Whistle
Also need to figure out all the ancillaries/requirements to finish off the V8 conversion, I'm aiming for a completely factory V8 setup so hopefully it should just all be 'off-the-shelf' parts for things like alternator bracket etc.
Lots of work ahead but dialling up the heat on this project to hopefully have it back on the road for end of July ish Shocked Matt.
Post #953023 20th May 2022 10:16am
Co1
Nice work!
Post #953041 20th May 2022 2:27pm
JOW240725
Very nice, great work! James
Instagram @suffolk_rovers
Post #953057 20th May 2022 6:46pm
Dinnu
Thumbs up from me too Thumbs Up
Love seeing an old 90 being rejuvenated Wink 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #953059 20th May 2022 7:34pm
L110CDL
Thanks for the update, a lot of work done there and at this rate, July is looking good Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #953063 20th May 2022 8:22pm
trickster5000
Big update Very Happy Lots of progress in the last 2 weeks
Got the engine and axles back to HQ:
Painted the new galv chassis with Buzzweld GIO, and tarted up the various suspension/steering arms, new bushes pressed in:
Then on went the front and rear axle assemblies, all reasonably easy when you've got full open access around the chassis. Had the usual fight with the bushes on the front shock absorber though, horrible things Rolling Eyes
Then bolted the clutch on and mated the transmission up to the engine, ready to drop into the chassis. Which is when the fun began Big Cry Lifted it in but with the gearbox mounts engaged in the holes, the engine mounts were roughly 2" short Big Cry
Bit of research I found that the 4cyl/200tdi transmission mounts I was using cause the transfer box to sit 2" further back and I needed the 300tdi/V8/Td5 gearbox crossmember with integrated gearbox mount points. Managed to get hold of the bits I need, swapped em out and problem solved Very Happy
Then spent some time finishing up bits of the engine: oil pump, valley gasket, rocker cover gaskets, inlet manifold and then showed up the Edelbrock carb to see how it's looking:
Still got the axle brake lines to do but began making a bracket for the rear axle pipework:
In for a trial fit then painting:
Plenty more tinkering to do but next big job to tackle is painting the new galvanised bulkhead and installing that, then attention can turn to wiring looms, finishing brake/clutch lines, fuel systems etc
Still targeting mid/late July completion! Embarassed Matt.
Post #953849 27th May 2022 8:30pm
Procta
great work there Thumbs Up i was wondering how you were getting on with your build Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #953857 28th May 2022 6:00am
Co1
Bow down
Post #953862 28th May 2022 7:41am
Dinnu
That is looking very nice Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #953864 28th May 2022 7:57am
familymad
Good work fella 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #953972 29th May 2022 2:21pm
trickster5000
Cheers all Thumbs Up
More progress this week, got the new galvanised bulkhead painted with a primer coat and then arles blue over the top - nothing fancy, just using a compressor sprayer gun but the finish looks pretty good.
Gave the wolfs a new coat of hammerite and put some part-worn Cooper mud terrains on - they're maybe a little bigger/wider than I really want but got them from a family member who was after a more road-friendly setup and I can always swap them at another time if they're too much.
Anyway, out into the sun for a few pics now it's a proper rolling chassis Very Happy
Suddenly mid-july completion is looking quite plausible Thumbs Up Matt.
Post #954348 1st Jun 2022 8:27pm
Arles blue and white Wolfs - what's not to like? Laughing Darren
Post #954353 1st Jun 2022 9:42pm
