Home > Technical > Defender engine for 2003 TD5 and 2014/16 tdci |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3216 |
For 2014/16, 2.2 engine, oil needs to be low ash, due to the dpg. oil spec advised on this thread:
https://www.defender2.net/forum/topic34176.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Oct 2021 5:10pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1794 |
As above you need specialised low SAPs oil for the the 2.2 TDCI from MY2012 due to the DPF being fitted. I use Millers XF Longlife C1, it performs well and if you do a search on line you can get it at a reasonable price. If doing oil changes I would recommend genuine LR oil filters as well. |
8th Oct 2021 5:30pm |
F and G are too close to each other
DPF I meant. +1 on Millers. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Oct 2021 6:56pm |
