Home > Maintenance & Modifications > Defender XS seats |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3214 |
Keep in mind, especially with the seat base, that you have to be able to remove it without cutting the wires... so a connector is needed. By default, seat base and seat back have 2 different connectors, but T connected.
Check the power (current) draw, so to make sure that the connector can easily handle it without melting. I buy in bulk 2 pin connectors (made in China as most other stuff is), but have been pleased with them. However highest power I connect is 25W, which is roughly 2A. But you will need a dedicated crimper, that folds and crimps the pin on the wire (and insulation for anchoring). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
4th Oct 2021 7:05am |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 295 |
Dinnu as usual you legend
4th Oct 2021 10:22am |
MGCarr Member Since: 18 Nov 2016 Location: Lancashire Posts: 59 |
I have fitted heated cloth XS seats to my 300tdi 90, l find them more comfortable if mounted on Mud seat rails. The incoming wiring goes to the seat back and a wire comes out from the back to go to a plug on the seat base - see pic
Click image to enlarge Sorry not the best pic. The only downside I find is that you can’t fit the original centre seat at the same time. |
4th Oct 2021 8:36pm |
Thanks for that I've got a cubby so should be okay with that.
4th Oct 2021 8:38pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
I have the half leather XS seats in Millie and all wired in and you can fit the middle seat in between them
Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
5th Oct 2021 10:12pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
I like the idea of a cubby but the middle seat just looks so nice and comes in handy on occasion.. 1993 200Tdi Defender 90
6th Oct 2021 9:50am |
