Home > Tdi > Light switch info |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4497 |
Which of these fits the 300 tdi
https://www.lrdirect.com/prc3430-supplied-...nded-lucas https://www.lrdirect.com/amr6104-supplied-...nded-lucas 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
17th Sep 2021 11:55pm |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 401 |
You want the first one, i've just changed mine on my Tdi and that's what was on mine.
18th Sep 2021 8:06am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Does it depend on your connectors? That one recommended has bullet connectors but check your old one as it may have pin connectors as ithe wiring may have been updated at some time. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
18th Sep 2021 9:05am |
The vehicle is not mine and is not here. It is a "J" registered 300 tdi, one of the very last. I know they changed connecting ends but was not sure when. I have a 200 tdi but I was not sure if the 300 tdi usedthe same connecting ends. Thanks. 1982 88" 2.25 diesel
18th Sep 2021 10:44am |
97 - 99 connector manual for TDI 300 show newer type blade connector for switch lighting C041 but as always best check
18th Sep 2021 11:15am |
Thank you. It is my daughter's 90 and she lives away. She will be here next week so Iwas going to get one and change it for her. Seems like the simplest thing to do is to order one of each! 1982 88" 2.25 diesel
18th Sep 2021 11:36am |
My duughter's chassis number begins VB67WA.
So does this come under VIN 6A999999 or VIN 7A000001 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
18th Sep 2021 11:59am |
6A = 2006
7A = 2007 |
18th Sep 2021 12:34pm |
No VB67(WA) V=90" L/R B = 2 Door station wagon 6= engine type ? 7 = gear box type 5 speed RHD WA= 1998 in Solihull build |
18th Sep 2021 1:11pm |
Thanks for the info. I have ordered one of each just to be sure!! 1982 88" 2.25 diesel
18th Sep 2021 1:15pm |
