Home > Technical > Connectors for Winch Power Cables |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 789 |
I am investigating options for connectors for 40sqmm cable for winch power and earth so I can remove the winch without unbolting from either battery or winch end. Clearly an Anderson connector is an option but I am looking for a single pole option with a smaller plug (for passing through holes).
Has anyone used welding cable connectors? Like these: Click image to enlarge Twist lock and copper connectors so should give decent current pass through and they are rated for larger cables (up to 95sqmm). https://www.1stopweldingshop.com/Catalogue...Type-Plugs |
10th Sep 2021 11:42am |
Tim2809 Member Since: 15 Aug 2021 Location: Dorset Posts: 21 |
Have used din plugs for years on recovery vehicles for the winch, we then also use same supply for jump leads so double purpose
12th Sep 2021 3:50pm |
