Home > In Car Electronics > Blank canvass - Alarm/Immobiliser/Tracker + central locking |
KylieTheOneTen Member Since: 29 Jan 2021 Location: North Yorkshire Posts: 10 |
Anybody got any advice??
13th Sep 2021 9:03am |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 295 |
Central locking is quite easy to install - there is a good UK Supplier call HAWK - they sell kits - alarm/central locking/immbollisers all in one kit.
Theres a few walkthrough guides installing these on defenders also. Usually a 2 hour job for someone with good car electric knowledge. If you want the rear door to be on the CL usually a bit harder to run the cables etc and fit the actuator with the way the defender rear door locking units work but it is doable. Check here; https://forums.lr4x4.com/topic/32024-fitti...fender-90/ https://www.ebay.co.uk/itm/233716715137 |
13th Sep 2021 9:49am |
Thanks Karl - appreciate you taking time out. It is reassuring to know that Hawk is the option you identified as it is one I have been investigating. Once the CL has been fitted is there a particular brand of alarm/immobiliser/tracker you'd recommend. I have been reading up on Scorpion - do you have an opinion on them?
13th Sep 2021 9:52am |
No worries.
I went with a Hawk alarm that has a loiter feature so if the alarm is set and someone is hanging about around your car it will sound a mini alarm before the full alarm actuates. Alarms and Immoblisier are only deterents and usually easy to get round for certain crims. Long as its loud as f*ck lol Get a pedal guard or a pedal pin for extra secruity. |
13th Sep 2021 9:55am |
Jizzer Member Since: 07 Dec 2021 Location: Dublin Posts: 4 |
hi karl could you point me in the direction of one of these walkthroughs just got a 110 td5 and need to secure it |
7th Dec 2021 9:53pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2631 |
Having 4 different trackers on my current cars, Vodafone / cobra track for me is the best.
7th Dec 2021 10:38pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1295 |
Hi can you please elaborate on why Vodaphone/Cobra track is best?
9th Dec 2021 10:47pm |
