Home > For Sale & Wanted > FS: Double Cardon Propshaft <suit TD5> |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
PM sent ti-fat-man.
As a general question to all here, will one of these fit my 110, or are they specific to a 90? I cant imagine the gearbox and engine would be mounted any differently on a 110 compared to a 90, so therefore the angle of drive on the shaft should be the same too. I need a definite answer on this one though, rather than a best guess, so if anyone has experience of this, please let me know. Best wishes to all, Landy nut |
7th Mar 2009 9:39pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
According to the D44 site it will be 44mm to short for a puma
8th Mar 2009 12:54am |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
Do you know if a TD5 front prop, will fit a rear Puma?
Some rumour i heard somewhere. Something about the gearbox being further back in the newer vehicle. Hence a shorter prop used for the rear. I get that, but not sure of the length of the Puma rear. Cheers al. |
8th Mar 2009 2:08pm |
Not sure about that one
8th Mar 2009 3:20pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2884 |
why have you taken it off the car
8th Mar 2009 6:10pm |
stripped it off my old TD5 when I sold it, replaced it with the stock jobbie.
was hoping at the time, that this would fit a Puma. it dont' hence is for sale, with the likleyhood that i've got to buy a new one of correct length to fit my Puma |
8th Mar 2009 6:37pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2272 |
The one fitting the Puma is that for the 200 Tdi Puma 110" SW
27th Mar 2009 12:56pm |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
you will need a td5 output flange to fit a td5 prop to a puma D44 can sort this I have one
30th Mar 2009 8:54am |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Is this still available? You cannot teach stupid people to do clever things
3rd Apr 2009 3:01pm |
