Home > Maintenance & Modifications > High pressure fuel supply eaten by animal!
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
While driving, I started smelling diesel. Stopped at the side of the road and there was some smoke as I opened the bonnet.
This was the problem:
There was lots of diesel around the injectors and running down the side of the engine. Also plenty of nut shells, so assume it was eaten by a mouse or similar.
Used some flexible hose as a fix to get back home (20km), but I assume this is not recommended for long:
Can the individual small length of damaged pipe be replaced, or do I need to buy all the high pressure pipes as a single assembly? It looks like each of the pieces can be connected individually, but I can't work out how they can be easily disassembled and reassembled. Any help (and part numbers I need to order if possible) would be very much appreciated.
Post #915110 2nd Aug 2021 8:39am
htb2
They are the leak off pipes and return to tank. The high pressure ones are the metal pipes to the injectors. Leak off pipes are available for Tdi and the likes, not sure for the TDCi though others with more knowledge will answer better, I have only got up to TD5 era.
Your repair will be ok in the short term, but make sure they are diesel resistant.
Post #915125 2nd Aug 2021 10:14am
donmacn
I believe you can also get 'rodent tape' which deters them in the first place.
I've no experience of it myself but a friend who's bulkhead I'm replacing at the moment is going to buy some for parts of his wiring loom that the mice have been nibbling. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #915126 2nd Aug 2021 10:21am
markb110
Time to replace the cat on the down pipe…… Mr. Green
Post #915133 2nd Aug 2021 11:54am
dorsetsmith
LR005749
Injection pump to manifold pipe JLR
Post #915134 2nd Aug 2021 11:55am
dorsetsmith
or install cat in fan shroud Whistle
Post #915135 2nd Aug 2021 11:56am
Tribord
A pity it only comes as an assembly instead of being able to replace single hose parts. I will order one though.
I looked into that rodent tape - it seems to not always be effective. thin paint laced with hot chilli pepper/powder looks to be quite popular and effective though!
Thanks all. Thumbs Up
Post #915196 2nd Aug 2021 8:03pm
