Home > General & Technical (L663) > Wheel arch extension pictures
Page 3 of 3 <123
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
J77 wrote:
At least that photo has made my mind up, definitely won’t bother with those. I liked them on my D3 but then that was designed to have them.
Looks fine without
Here,here. Staying well clear of ‘em. As you say J77 it looks fine without Thumbs Up Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #910762 4th Jul 2021 9:10pm
Scrumps
United Kingdom 2005 Defender 90 Td5 CSW Cairns Blue
Peanutbob,
If you have them fitted at PDI you get a 3yr warranty on accessories….so no worries if there are issues.
Scrumps[/b] 90 D250 HSE Tasman Blue
24MY L461 RRS Verasine Blue
05 TD5 90 CSW Cairns Blue
1967 MGB BRG
1944 Willy’s MB OD green
1942 Willy’s MB OD green
Post #912011 12th Jul 2021 10:55am
4B4B
peanutbob wrote:
3. This thin tape is unlikely IMO to remain effective during a U.K. wet winter. Water will ingress and damp anyway. I guess you could use double sided number plate tape which is very resilient but if ever the arches were taken off, then there would be a heck of a job to remove this tape without damaging the paint.
I've had LR rubbing strips on the doors of an 18 year old Land Rover, which are held on with what looks like the same type of 3M tape. Over that time, and through many a wet winter, they've stayed solid.
peanutbob wrote:
The arches look great, but I wouldn’t be happy after spending £612 if they started to fall off .
I agree on both points. It would be pretty naff if they started to buckle off after paying so much.
It's possible to fit them DIY, and therefore take time and make sure you do a good preparation job prior to fixing. But they still cost £500, and I can imagine that if the DIY fitment started to come away, the dealer will just say they 'weren't professionally fitted', and want nothing more to do with it. So I may just bite the bullet, and have them do it, and hope they don't rush the prep. To get the 3 year warranty. Defender 90 HSE 250D 2022MY - Gave up after two failed orders
Post #912156 13th Jul 2021 10:57am
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
I fitted mine on Sunday. I took my time on surface preparation, and everything went broadly to plan.
The fixtures certainly seem pretty robust; and I was impressed at the way the double-sided tape (post clean, alcohol wipe and adhesion promoter) immediately pulled the trims onto the body - leaving none of the gaps seen elsewhere on this thread.
The standard trims came away pretty easily, and the whole job was done in about two hours. I’m an enthusiastic amateur, at best…
Post #912169 13th Jul 2021 12:33pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
“ I’m an enthusiastic amateur, at best…” Laughing .. I might have to use this.
They look good and love the wheels. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #912172 13th Jul 2021 12:45pm
4B4B
+1 on the above comment.
Great looking job and 110. Defender 90 HSE 250D 2022MY - Gave up after two failed orders
Post #912203 13th Jul 2021 4:07pm
Ronin
Thumbs Up Thumbs Up
Post #912245 13th Jul 2021 8:09pm
Page 3 of 3 <123
