Home > Technical > Air con condenser
Page 2 of 4 <1234>
geobloke
Oooo yeah they cost... mine is an aftermarket system made by Coolair and their condenser is very different to the LR item. Still it costs about the same ...
Just in case you are wondering it looks like this:
I have wondered about re-coring and didn’t get very far as the repair was interrupted by a house move. Might be time to reach out to a few companies...
Any suggestions?
Post #903880 19th May 2021 11:11am
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
400 and something pounds I paid for mine last year.
I couldn't find anything cheaper.
Fabio
Post #904014 20th May 2021 6:05am
jst
So my 2010 2.4 110 is loosing aircon gas and its not immediately obvious where from. tired dye etc. its on the original condensor which looks ok - for its age........
its 11 years old
should it be changed is it likely to be failure point or more likely the joint such and such always fails and is worth checking first. what tests can i do. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #904999 25th May 2021 8:24pm
Fabio
Mine was leaking at the back.
Couldn’t see the leak unless it was taken apart.
I did a few things that others advised but in the end had to change it.
Charging it costs quite a bit and unlike what people said the machine charging it never came up with errors because it did hold gas for a few weeks.
Mine was 9 years old.
Fabio
Post #905041 26th May 2021 5:50am
jst
at the back of the condensor?
how long would people expect these to last? Cheers
James
110 XS Utility
90 Puma Hardtop
Post #905226 26th May 2021 10:56pm
Fabio
Yes mine was leaking badly at the back.
It is very easy to take off and see.
Fabio
Post #905235 27th May 2021 5:46am
hank
Timcat wrote:
Interested in one also Gary, ours is about shot.
Me too. Been trying to source an alternative or take off part for ages. Price is ridiculous > 110 XS Double Cab
> Instagram @simonlanemind
Post #905268 27th May 2021 10:13am
Bluest
Can these not be recored like a radiator? 2007 110 TDCi Station Wagon XS
Post #905288 27th May 2021 12:09pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I had no idea these were so expensive. Looks like they're all complete with frame and fan.
Glad to say mine's working fine at the moment (2014 model).
I've got an intercooler to go in at somepoint soon, and I was thinking of renewing the condenser 'while in there' as a sort of service item... but £500 is a bit much for that!
Post #905292 27th May 2021 12:45pm
hank
I've been through the Nissens catalogue based on condenser core dimensions (800mm x 300mm approx) and out of 162 results I think I've found three cores that look as though they could work - suitably sized with the inlet/outlet in the correct location.
Does anybody know the hose fitting size and the flange bolt size of the original Defender condenser? > 110 XS Double Cab
Post #905332 27th May 2021 4:54pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Just posted an order for an air-conditioning condenser with island 4x4 which has the condenser in stock.... still in the mid £400 range including VAT (20%) but free delivery Whistle
However if you are looking to order you will need to add ‘o’ rings too which are not included in the price ..
www.island-4x4.co.uk
O-Ring (OEM) JUU500120
Air Conditioning Condensor Td5 2.4 Puma (OEM) JRB000051 LR025985
So will see how I get on fitting this and fingers crossed it all works fine ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #906004 1st Jun 2021 7:07pm
wyvern
landy andy wrote:
Ever since replacing mine I’ve had a fine mesh behind the grill, to save paying out again. Twisted Evil
What mesh behind the grill did you use Andy ??
As I am about to do this job it may be a prudent time to add another layer of protection to the system .... or would it be better to replace the original plastic vented grill with a ‘series stye’ mesh type ?
Cheers !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #906007 1st Jun 2021 7:15pm
landy andy
It was just some 10mm hole mesh and bent it about, a few clever cuts and it holds its self in place. It’s been fitted to a few different grills now. I’ve also done the same to my Fiat based motorhome with black mesh. Got that stuff off eBay.
Post #906032 1st Jun 2021 9:23pm
I fitted some mesh recently, Wyvern, so this might help: https://www.defender2.net/forum/post900141.html#900141
 Darren
Post #906081 2nd Jun 2021 6:29am
wyvern
Hi all
have just fitted the new condenser to :Poppy and the job was not hard to do ...
The box .. pre work -
After removing the grill - lots of damage to the fins and the core was bent - ? from something that happened prior to my ownership ..
the condenser was removed after undoing 3 bolts and then disconnecting the cooling media lines .
new condenser fitted - took a couple of mins to gently aline one of the cooling lines due to the old condenser being pushed bak at some time
calling medium being added after 15 min pressure test - then tested - good results !
Post #908795 21st Jun 2021 4:58pm
Page 2 of 4 <1234>
