Home > Maintenance & Modifications > 300tdi clock replacement ideas?
CarMan
I use a battery cut-off when parked for security and it does my nut in that the clock doesn't tell the correct time, so it's coming out Rolling Eyes
I can blank the hole, but maybe I could add a gauge - what would you do Question
Must be in-keeping style wise, but I'm thinking maybe revs or boost - needs to be not hard to install Laughing
Ideas please Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #902210 9th May 2021 6:21pm
markb110
Technically it is correct twice a day………. Whistle
That reminds me, my clock is still on British Winter Time. Almost not worth changing it now, judging by the weather here Laughing
Post #902214 9th May 2021 6:36pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
I had a battery cut off on my 300tdi and i ran a low amp fused link between the terminals. It kept the clock, interior light, dash lights and stereo memory working but any attempt to start the car would blow the fuse.
Post #902217 9th May 2021 6:38pm
Retroanaconda
Put a small fuse across the isolator, it will keep your clock going (and radio memory etc.) but will blow if someone tries to start the car.
Edit: Bah - beaten to it by a second! Laughing
Post #902218 9th May 2021 6:38pm
CarMan
Thanks for the suggestions. I left it isolated for 6 months last Winter and it started first turn, so quite like the idea of completely isolating as it avoided any battery issues
Post #902288 10th May 2021 7:08am
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Cunning....What size fuse , ampage wise did you use? Cheers
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #902304 10th May 2021 8:39am
Litch
My 90 has been set up like that for nearly 20-yrs.
Small (fused) supply off perm live side of FIA isolator which serves alarm, tracking device, radio, clock, and an interior light. This feed is fused at source so any damage to the cable will blow the fuse (which is inches away from the FIA switch) but the remainder of the vehicle is isolated when switched off. ONE LIFE, GET IT!
Post #902416 10th May 2021 5:06pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
If you don’t have, then a voltmeter I have found very useful when winching and can give early warning of alternator failure 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #902417 10th May 2021 5:33pm
Dinnu
I would put an oil pressure gauge. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #902418 10th May 2021 5:44pm
L110CDL
I have took the clock out as it would not work to change the hour twice a year, not bad for the original one, so i got a boost gauge fitted Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #902460 10th May 2021 9:42pm
Procta
Re: 300tdi clock replacement ideas?
have a look at this, pay attention to the wiring Thumbs Up This is designed to keep the alarm features etc on line, but as soon as some Censored starts the car, that goes pop and the full works is dead in the water.
https://www.ebay.co.uk/itm/123461298296?ep...SwFYZb2sBg Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #902504 11th May 2021 12:16am
CarMan
Well, after a year, unsurprisingly this issue has not gone away, so it's decision time!
I feel a blank looks a bit low rent, but the solution must be period correct, so I'm thinking a voltmeter or oil pressure gauge might just be a suitable replacement for the clock.
But, will it be difficult for a numpty to wire the voltmeter? Oil pressure gauge more difficult I assume??
I would prefer used, to be in keeping with the existing fuel gauge and water temperature so if anyone has anything please fell free to let me know.
Thumbs Up
Post #954821 7th Jun 2022 5:27pm
rallysteve
Have you thought about trying the clock with a 9V battery? Fairly sure it would still work and the battery should last a decent amount of time.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #954827 7th Jun 2022 6:30pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
As has already been suggested, just bridge the isolator switch with a small fuse, 3 or 5 amp should be plenty and will pop as soon as the heater plugs or starter motor are activated.
This will cover you for keeping the clock & radio active during day to day use (apart from when you keep forgetting to switch the isolator back on Rolling Eyes ) and just requires removal of the fuse for longer periods of inactivity such as winter lay-ups etc. Setting the clock in the spring after a long period is no real hardship?
Post #954847 7th Jun 2022 7:36pm
Or.... if you didn't want to keep any of the other electronics live (alarm/interior lights etc), then run a +ve cable from the clock back down to the battery, add a fuse at the battery end and connect it directly to the +ve terminal of the battery (or the live side of the cut off switch)
That way when you turn the switch off then everything will be off apart from the clock.
But I feel it would be better to have the alarm live as well.
Post #954897 8th Jun 2022 7:57am
