Home > Wheels & Tyres > Help - I have a bad case of indecision!
Page 1 of 3 123>
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Greetings all,
I two sets of wheels and tires - SVX alloys with Conti Crosscontact and Black Sawtooths with Hakkapeliittas
Both are 235/85R16. The Contis are from 12/14 and the Nokians from 01/15. Both sets are worn about 40% (60% remaining).
I like the
Look of the sawtooths better; two colours on the truck looks good to me, 3 colours is a bit busy.
I need to keep the Hakkapeliittas, but want Summers on the Sawtooths... and I’m not a fan of remounting tires (always thought this was sun optimal, but I could be wrong).
My Contis don’t balance that well. One of them needs 32g to balance.
I drive several thousand km in the summer in one go (CH to NO and CH to Sardinia) so I do feel the need for a summer tire, not to mention the off-roading, for which the Contis have been fine.
I could remount the Contis on my Sawtooths
Get some new summers for the Sawtooths and remount the Nokians on some steelies this fall
Do nothing and stop complaining
Or?
So what would you do?
 Roaming around 🇳🇴🇨🇭
Post #899185 20th Apr 2021 4:32pm
JOW240725
As Tommy Cooper said "I used to be indecisive but now I am not quite sure." Laughing
Fit KO2's to the Sawtooths for summer use and the get a set of et0 black modulars for the Happekkas for winter? James
Instagram @suffolk_rovers
Post #899221 20th Apr 2021 7:44pm
Stacey007
Hello
I like sawtooths as I have them (and conti's) but after 5 years I'm looking for a change also...
Since lockdown though I have not used my car as much so done nothing about it...
one of my options were / are these in 18"
my current ones...
but I also like the mini monster truck 'look'
So for now I'm doing nothing Very Happy
Post #899223 20th Apr 2021 8:02pm
Angus_Beef
Hi Stacey, those 18” Sawtooths would certainly look fantastic on your all black 110!
At the moment I’ve googled my way to thinking the 255/85 KM2s on my Sawtooths might be just the ticket for an all season... Roaming around 🇳🇴🇨🇭
Post #899229 20th Apr 2021 8:41pm
Angus_Beef
Several beers worth of thought is now leading me to body coloured wolfs with 255/85 KM2s 🙈
Despite the weight, they should look nice with the unpainted fender flares and black roof.
Now to sort informing SWAMBO... Roaming around 🇳🇴🇨🇭
Post #900097 26th Apr 2021 4:43pm
CarMan
Personally, I would be concerned about the turning circle with Sawtooth's and 255's, which would be helped by the offset of the Wolfs Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #900099 26th Apr 2021 4:49pm
Angus_Beef
Valid point CarMan, and not something that I had considered. Thanks.
My path is becoming clearer Roaming around 🇳🇴🇨🇭
Post #900104 26th Apr 2021 5:14pm
Having had both, I can say that there's about 6mm difference between Wolfs and Sawtooths. The latter have a different offset to the majority of standard LR alloys (about 22mm v 33mm), which brings the inner edge to virtually the same position as the narrower Wolf. Darren
Post #900109 26th Apr 2021 5:45pm
CarMan
Every day is apparently a school day - I didn't know that Rolling Eyes
Post #900110 26th Apr 2021 5:52pm
JOW240725
I wouldnt be concerned with 255 on sawtooths or genuine wolf. However, personally, I'd choose Wolf style et0 rims for maximum offset to improve turning circle and look great! Just my personal opinion though. James
Post #900113 26th Apr 2021 6:34pm
Angus_Beef
Thanks guys, this is a lot of help.
Seems the original Wolfs are et20,6 ? LRA are these the ones your refer to?
Keeping original helps my dear Swiss inspectors stay happy... Roaming around 🇳🇴🇨🇭
Post #900269 27th Apr 2021 7:57pm
Grenadier
Whatever the wheel, I do prefer them to be a different colour to the body(black on black being the exception). Wolfs yes, but against grey I'd have to say black, not body coloured. Of the remaining two, the Sawtooths as I prefer the greater contrast of the black against your grey, to the silver of the SVXs. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #900277 27th Apr 2021 9:07pm
Ianh
I run 265/75 MT’s on genuine LR 16 inch sawtooth rims. So these are wider than 255/85’s but smaller in diameter. I have not had any issues with steering lock so with the 255’s being narrower I think they will be fine on sawtooths or gen wolfs as they have the same offset. I think KM2’s have now been replaced with KM3’s.
My next set of tyres will likely be 255/85 r16 KM3’s, so will follow how you get on if you go that route. Just make sure your insurance company is aware you are running different tyres from the 235/85’s.
Post #900280 27th Apr 2021 9:26pm
Yeah, they're the ones. I was close... Darren
Post #900288 27th Apr 2021 9:55pm
Angus_Beef
LRA, perfect, thanks for the guidance. I’ve read through all the threads I could find on wolfs and learned that there is only one real HD 6.5x16 and that’s the et20,6 you referred to. The et0 copies confounded me for a bit, and they wouldn’t have worked for me as I need the DTC papers for the Swiss authorities.
Now I’m down to two finalists - 265/75 KO2s on ANRs or 255/85 KM3s on LR Wolfs.
I like the 255 size better. The height and width. But dislike the weight. 45kg or so per corner is wild.
The KO2s are probably more “appropriate” for the amount of tarmac driving I do but they look a bit meh in my opinion.
So to my friends running KM2/3s... how bad are they really? I know it’s a mud tire. Can you reasonably drive 500 miles in a go?
 Roaming around 🇳🇴🇨🇭
Post #900423 28th Apr 2021 8:29pm
Page 1 of 3 123>
