Home > General & Technical (L663) > Clearview Camera Shark Fin Antenna |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3259 |
Definitely something to watch, though I didn’t option the clearsight camera, so might be a bit cheaper if I do forget. One car park I do use my 90 definitely won’t fit under the barrier, even if I took air suspension it would be touch and go. 24MY 90 D250 HSE, Tasman Blue
30th Mar 2021 11:24am |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 |
having a rack or bars provides the relevant protection to the antenna (though theimpact of a hit will be much larger )
I know a 2.0m height limit means I will have to be in access mode to get under it going forwards - I'm probably going to go do a trial run at the local time during a quiet period to be certain! Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
30th Mar 2021 11:38am |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
That damage looks like it just needs a little bit of superglue.
Carefully of course. |
30th Mar 2021 12:20pm |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
Been there got the t shirt 👕
Before:- Click image to enlarge After:- Click image to enlarge It was transporter damage, got an extra years warranty compensation |
30th Mar 2021 12:53pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2527 |
Perhaps the Clearsite camera needs to point forwards......
30th Mar 2021 3:57pm |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Been thinking about this before as I paid dearly already, too.
https://www.defender2.net/forum/post882466.html#882466 |
30th Mar 2021 4:23pm |
Or if there was a vertical red bar showing your height limit in the mirror Click image to enlarge Or would wade sensors turned upside down give you sky sensors? |
30th Mar 2021 5:06pm |
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 |
did exactly that last year with my shark fin, ended up with new roof !! but i must say NFU were brilliant and just said get ir done
30th Mar 2021 5:34pm |
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 |
30th Mar 2021 6:29pm |
Tricky C Member Since: 31 Jan 2024 Location: West Midlands Posts: 1 |
did you get the casing sorted for your clear site camera in the end.
got the same issue with mine, been quoted £180 inc vat because you need the whole casing and £600 for 3 hours labour to fit. seems a bit excessive to me when all i need is the top part of the casing, so labour should be about 5 minutes. did you buy the case and fit it yourself in the end. |
31st Jan 2024 7:23pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2277 |
£200 per hour
l am in the wrong trade. |
31st Jan 2024 8:50pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 125 |
PowerfulUK do some dummy shark fins, maybe one could be cannibalised to fit? Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
31st Jan 2024 10:22pm |
Ronnieh Member Since: 05 Jul 2023 Location: Lancashire Posts: 7 |
Been there and done it I'm afraid on my own garage door! £25 from Powerfuluk fixed it. 2023 X Dynamic HSE 90 D250 MY24, Air suspension, HUD, Clear sight, Electric tow bar
Santorini Black |
8th Mar 2024 5:37pm |
