Home > Td5 > Central locking |
all the doors that are not unlocking or drives door
11th Feb 2021 1:22pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1825 |
Can you explain in more detail what’s happing ? Are the locks trying to lock and then bounce back, is there no movement at all. When in vehicle with engine running can you lock the doors by pressing the drivers door button down, can you unlock or lock with key.
Many of these problems manifest themselves during the cold weather, a lot of times it’s the drivers door mechanism that’s frozen, either the lock barrel or lock mechanism. These can be cured with cleaning and graphite puffed into the lock and mechanism. If it’s not frozen or jammed locks and getting no movement when pressing down buttons it can be a broken wire in the loom between body and door, or blown fuse , or bad earth etc. So doing a few tests as above and providing info on what you observe will help localising the issue. Ps when running tests have at least one window wide open so if something is stiff and then locks but won’t open again you can get back in. |
11th Feb 2021 2:18pm |
countyboy Member Since: 24 Oct 2015 Location: leicestershire Posts: 32 |
Thanks for the replies
When I press the blipper there is usually a loud click and the indicators flash. Now there is nothing happening. I will need to make further checks (remembering to have a window open) Regards Robert |
11th Feb 2021 5:14pm |
fuse 6 20 amp under drivers seat fuse box
fuse 8 10 amp passenger fuse box |
11th Feb 2021 6:59pm |
Thanks I will check
Regards Robert |
12th Feb 2021 12:42pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
if it was always working and you didn't mess with it. it's most likely a blown fuse from a broken wire that shorted out at one of the doors. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
12th Feb 2021 2:09pm |
Ok Thank you
Regards Robert |
13th Feb 2021 4:37pm |
