Home > Technical > Front Shock Tower Height
kenzle8a
Hello collective,
My Defender came with tubular shock mounts on, I'm not sure if they are made specifically for the +2 lift it has, I'm about to remove the lift kit and go back to standard.
Could someone please tell me how tall the front shock towers are so I can check to see if mine need replaced with normal height ones.
Post #880773 25th Jan 2021 2:09pm
dorsetsmith
270mm
Post #880786 25th Jan 2021 3:11pm
kenzle8a
Ah thanks, mine are indeed higher than stock.
Post #880876 25th Jan 2021 10:21pm
If you're changing back to standard height then you can't go wrong with the galvanised offering from Gwyn Lewis.
 Darren
Post #880896 25th Jan 2021 11:00pm
kenzle8a
My bill from Gwyn is going to be a big one this month then Laughing I've already replaced the prop shafts and a few other bits and bobs from the old owners running the car lifted for a long time on the stock items.
Post #880945 26th Jan 2021 9:33am
Heh, heh, excellent Laughing Darren
Post #880968 26th Jan 2021 10:43am
jimbo55
Can’t really go wrong buying Gwyns stuff, not cheap, but all works as it should and lasts a long time,
Post #880979 26th Jan 2021 11:16am
