Home > Puma (Tdci) > Starting problem |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5449 |
20th Dec 2020 7:31pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
potential fuel leek sounds like there is no fuel on start up hence why its ok after one day but longer after being standing . can you here the pump running if so see how much longer it runs for after being stood a few days before starting
21st Dec 2020 8:14am |
LRnovice Member Since: 08 May 2008 Location: Cardiff Posts: 59 |
Thanks Andy Ill check that
21st Dec 2020 2:29pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 811 |
Could also be the starter motor on its way out...lots have had this issue....I'd recommend replacing it with a Bosch one
N. |
21st Dec 2020 6:47pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1732 |
Dont think theres an electric pump on a 2.4. Could be a leak giving an air lock though or dodgy / not tightened filter?
Keith |
21st Dec 2020 9:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16982 |
Correct, no electric pump on a 2.4.
21st Dec 2020 10:23pm |
i stand corrected thanks guys
22nd Dec 2020 8:42am |
blurry Member Since: 20 Oct 2020 Location: Wales Posts: 5 |
I have just had a heap of things checked for a similar intermittent starting problem.
One is the sensor and valve at the end of the fuel rail. The second, which cleared the problem, was the fuel pressure valve that is on the fuel pump, simple unplug old one, plug new one in, cost about £90 though. |
22nd Dec 2020 3:02pm |
