Home > Td5 > clutch / flywheel vibration at high revs |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
Check the propshaft UJs for play or seizure.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
9th Aug 2020 10:06am |
theheffman Member Since: 21 Mar 2019 Location: bath Posts: 60 |
more information on this.
Changed the front propshaft, its made no difference. The vibration occurs in all gears at high revs and load, when cruising at 70 its bad. Lifting off the accelerator removes the vibration almost immediately. Also when in neutral and not moving i rev the engine and hear / feel vibration. So i am thinking this is not transmission / propshaft related. (engine has only done 70k miles) Also on my list of things to check 1. engine mounts 2. crank shaft pully 3. flywheel (my current view of the trouble) any ideas on how to find the root cause, without spending a shed load of time and money ? thanks john |
28th Sep 2020 11:00pm |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 80 |
I’m interested in this as well as I have a similar vibration on my Td5.
I’ve changed the flywheel, clutch and front damper but it is still there at higher speeds. Have checked the props and can’t find any play, have also removed them to check the joints aren’t seized. If I get any further with mine I’ll let you know. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
29th Sep 2020 7:02pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Mine turned out to be the transfer box , total saga trying to get to the bottom of it and replaced everything on the assumption that the “new” transfer box was good .
It turned out that it wasn’t but only after I had replaced the entire drivetrain . My symptoms were slightly different in that I was getting a vibration in all gears and at all speeds . It did however get considerably worse the fastest you went . You say you’re getting the vibrations in neutral at a standstill , try placing the transfer box into neutral as well and see if it makes a difference . https://www.instagram.com/hustynminepark/ |
29th Sep 2020 7:08pm |
good point, i will try this tomorrow. it does sound like the vibration is coming from the front. But i know how deceptive these vibrations can be.
29th Sep 2020 8:03pm |
wow thats an expensive list of things to change for the issue still to happen. Have you checked the injectors, i have read that an in balance can cause vibrations |
29th Sep 2020 8:07pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 581 |
What about engine and/or gearbox mounts? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
30th Sep 2020 10:41am |
a brief inspection of the mounts leads me to think they are ok. But i really do not know the best way to check.
Any tips ? I have considered strapping a go pro under the car to see if the vibration is visible:) not sure how effective this will be . |
30th Sep 2020 11:09am |
Mine runs very well so I don't think it is an injector issue but will have a look.
Good shout about the mounts I know they can cause issues when they fail. The front damper on mine was tired at 165k but I only replaced the flywheel and clutch as I had the gearbox out. I can live with it as it's not too bad and can be improved by speeding up or slowing down slightly which is what made me think it was a balance issue somewhere. It's just frustrating as I know something is not quite right but I can't find the issue. I'm tempted to replace the props but not in a rush to throw money at the issue. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
30th Sep 2020 11:14am |
i have changed both front and rear prop, made a massive difference. Not completely smooth at high revs, but it is a 5 cylinder lump after all.
will work my way though other parts in due course, engine and gearbox mounts. cheers |
11th Oct 2020 7:15pm |
Thanks for the update.
I've got the feeling this will be my next move as well. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
12th Oct 2020 4:50pm |
