Home > For Sale & Wanted > [Wanted] Td5 Sump |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Gathering things together for my rebuild during which I want to address the two leaks from my Td5. One leak is the rear of the sump gasket and the other is from the rotary filter drain because the threads on the sump studs are damaged so it cant be properly tightened.
Does anyone have a Td5 sump spare please? Dont think there is any difference between D2/Def/15p or 10p engines. Ebay ones seem a bit steep! Thanks Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
13th Aug 2020 5:09pm |
Fair point, hadnt looked at removing the studs!
Will investigate further, it is the thread where the nuts go which has gone so swapping them out would solve the issue i think. If not i can helicoil i guess. Cheers! Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
13th Aug 2020 7:02pm |
