Home > Off Topic > UV activated glue for glass |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19652 |
How about something like SMD Sunflash? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
13th Aug 2020 11:11am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16935 |
I can't answer your question, I am afraid, but from my limited experience with stained glass windows I would have thought that if you remove the lead you'll find that the glass pieces don't fit together very well. If the window is of value (historic or sentimental) I would think you'd be better of getting it re-leaded.
Alternatively see if you can get it done by "The Repair Shop". |
13th Aug 2020 11:16am |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
https://www.bing.com/videos/search?q=uv+gl...;FORM=VIRE
Seen many videos of uv light glues always look too good to be true! |
13th Aug 2020 12:01pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 721 |
Please don't do this.
If it is original then it is well worth saving. If you are good with a soldering iron then you can re- make the panel using new lead. I have a hundred year old panel, which I have repaired, and also sourced old glass to replace a broken piece. Alternatively , you should be able to find someone local who can professionally repair it. |
13th Aug 2020 12:25pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
To answer your specific question. Loctite make many different UV cure adhesives aimed at the industrial market, but some can be found at CPC, RS or Rapid etc who will sell to public. (I'm not disagreeing with anyone who says there are better ways to repair leaded stained glass) |
13th Aug 2020 3:12pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3217 |
I agree with what was said earlier, restoration keeping it to look as period as possible is best.
However, for UV glue, you might search "Loca glue". I used it for repairing mobile phone screens. But might be expensive in large scale. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
13th Aug 2020 5:15pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
What he said - the glass will be sized to allow for the thickness of the lead between each piece. |
13th Aug 2020 7:39pm |
