Home > Puma (Tdci) > Puma Rear Door Grill |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1833 |
Do you mean an internal security grille to cover the window?
I could easily be wrong, but I don't think they were ever standard, so you'll need to consider drilling the door to use self-tappers (I'd use stainless here) or using rivnuts. I did this recently with a black grille, and black, stainless socket screws - it looks 'factory' really. I think the windows are all the same size, but there might be differences in the grille shape relating to any wiper motors or internal grab handles. I used an MSS (Mobile Storage Systems) one. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
1st Jul 2020 11:23pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
Adding to the above... LR do an internal grill, but as stated they are actually dealer fitted by drilling and using self tappers. I had mine from new, but am considering changing to rivnuts and machine screws. Other brands are available and you can get internal or external. One difference with Pumas from early ones is a cut out for the high level brake light.
1st Jul 2020 11:34pm |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 401 |
Thanks Gents
And yes, I should have said internal window guard. I will have a look at MSS, I completely forgot about them, Strange considering that I actually purchased a set of the internal side window guards which I never fitted and are at Present languishing upstairs in the attic along with a number of other semi forgotten Land Rover purchases! |
1st Jul 2020 11:57pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1878 |
I’ve just ordered one from Flatdog and will match my cages and shelves.
Looking to fit mine with small rivnuts so it can be removed to access the glass 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd Jul 2020 7:00am |
Will have a look at Flatdogs offering.
I have used them a lot in the past. Would be my intention to fit with rivnuts also if I can find a tool that doesn’t require the biceps of a Bodybuilder to operate. |
2nd Jul 2020 9:43pm |
Pjembe Member Since: 21 Jul 2015 Location: Newbiggin by the Sea Posts: 143 |
Mud Stuff also do one (including cut out version for high level brake light) The design is so that you can fit a range of Molle pouches if desired
2nd Jul 2020 10:09pm |
I've got the Mantec one in mine, which was already fitted when I bought it:
Click image to enlarge It does the job ok but is only fitted with self-tappers. On my list of things to do at some point is to refit it with rivnuts, which I think is a better long term fixing. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd Jul 2020 10:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16979 |
That must make cleaning the window something of a challenge.
3rd Jul 2020 8:48am |
Yes That's why I intend to change the fixings, to be honest, as it is necessary to remove it every now and then. Darren
3rd Jul 2020 10:17am |
