Home > Off Topic > Paint sprayer-domestic/professional- any experience? |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 |
Hi
I am looking for a paint sprayer. Each year we have a lot of painting to do here. Some of it is creosote type of painting ( some are water based & some oil based) in areas without any power. I intend to use a Honda inverter generator as my power supply. I also need to paint our house with an external type of masonry paint. Budget is probably around £200-£300 for the sprayer. Any ideas as to what works & what to avoid? On the generator front ;Honda do two small generators ; a 1kw or a 2kw - any views on these or an alternative? TIA Guy May your life be like toilet paper ; long & useful. |
13th Jun 2020 7:58am |
http://www.wagnerprojectpro.co.uk/wagner-h...unted.html
What about the Wagner Pro at £399 inc vat ( I am vat rated) OR am I better in getting a Pro119 ? Still learning about the different features I see what you mean about Masonry paint but until you actually use one it is difficult to know which can handle that paint and those which really can't. Guy May your life be like toilet paper ; long & useful. |
13th Jun 2020 11:18am |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1031 |
That one is the updated version of the Project Pro.
Assisted airless is the daddy on all air sprayers ( using compressors ) and Wagner have got halfway there with their HEA system by using less air to atomise the paint. I've never used their HEA system as we tend to stick with Graco ( we got a deal with them ) but if it's an advancement on the project pro, you will get good results Any professional sprayer will handle masonary or thicker paints, it is just down to working out the best mix to use. Masonary can be a pain when mixed with water as it seperates in your bucket and needs constant mixing to keep it together, but it's certainly workable. |
13th Jun 2020 11:48am |
Badger;My Wagner 250M arrived today & l actually read the manual a number of times before trying to spray my new workshop with a white Matt emulsion which l had already done a coat with using a roller.
Some bits have worked out fairly ok & others not so good. I am rapidly learning that there is a bit more to spraying than meets the eye. Any suggested videos to watch to help me learn a bit more? Cheers Guy May your life be like toilet paper ; long & useful. |
17th Jun 2020 8:05pm |
Good news on your new kit!
A tip I would give you is to practice with just water on scrap cardboard. Set up your sprayer with a bucket of clean water instead of paint and test your spray patterns & methods of working on this. You;ll see how the gun reacts to the way in which you hold and move it as well get used to the feel of using the sprayer with a hose attached without worrying about wasting paint or learning the hard way. I don’t have any particular videos to recommend as there are so many of them telling you the same thing, but if you have a specific area you want some advice I can try and help |
17th Jun 2020 11:13pm |
