Home > Puma (Tdci) > Is my gearbox on the way out? |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Sounds like sticky selectors pop the top of and give it some grease also worth a oil change if not been done for a while 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
25th May 2020 9:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16979 |
It could also be the clutch dragging.
25th May 2020 9:36pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19690 |
Checking the gearstick lower assembly would be a good option I think, perhaps it is damaged as that will cause difficulty in selecting gears.
Might be worth looking before looking into the more costly side. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
25th May 2020 9:55pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2012 |
Have you also got the dreaded clutch rattle?
25th May 2020 10:23pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 297 |
Have a look at the gearbox selector bias springs, it sounds like they need adjustment.
26th May 2020 5:57am |
Mack Member Since: 11 Jan 2014 Location: Central America Posts: 58 |
I had the same symptoms for a few days last time my clutch gave in. New oil, clutch and slickshift solved the issue. Shifted like a dream until now that its in the shop for a new clutch. Many moons after though
27th May 2020 12:20am |
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 58 |
It sounds like it may be the clutch, and I've been quoted £1000 to replace it. Is that a reasonable figure?
2nd Jun 2020 4:51pm |
It sounds reasonable, in my location its around $ 2500 usd for a definite solution with labor (shipping and taxes are brutal). Go all the way for a lof clutch or a clutchfix and never look back. Will cost more, but worth every penny and cheaper in the long run (no more replacements due to spring failures with good meat in friction plates). Im just in the process for upgrading to lof (my flywheel arrives today), went full kit with power sping and master cylinder upgrade. My last kit did 150 k km (AP), being very gentle on the clutch always.
Cheers Mack |
2nd Jun 2020 5:19pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3618 |
in the midlands that would be lot for a clutch change by a good indi DEFENDER 90 TDCI XS,
2nd Jun 2020 6:36pm |
That quote was from in independent LR specialist I've used before in Bedfordshire.
I've had cheaper online quotes from 'normal' car garages. Would you trust a non LR specialist to do it? I'm in two minds about it. |
4th Jun 2020 4:45pm |
