Home > Maintenance & Modifications > Aquasteel rust converter |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Everything you need, made in Britain, is available from here (as used by me):
www.bilthamber.com |
25th May 2020 7:35am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16954 |
I've used Aquasteel and it does exactly what it says on the bottle and does it well. I think most if not all modern rust converters now are tannic acid based and convert the rust to iron tannate, with a polymer overcoating, and to a great extent all such converters will be much the same.
I've also used dilute phosphoric acid for the same purpose in connection with heavy machinery restoration and needle-gunning or wet-blasting, followed by a dilute phosphoric acid wash, priming, undercoating, and top-coating, produced adhesion and protection results that exceed North Sea Offshore industry standards. Rather more hassle than you want, I suspect, though. Tannic acid converters are generally pretty safe and benign, the older phosphoric and hydrochloric acid based converters are less idiot-friendly and tend to give off harmful fumes, etc. For this reason they are no longer particularly easy to obtain - we have to be protected from ourselves, after all. Keep the bad genes in the pool, and all that. |
25th May 2020 8:06am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 552 |
I have used the Aquasteel before and I have been happy with what it has done - but not under a land rover. I have not had the experience of it getting covered in mud and road grime. In your experience does it stay stuck to the steel?
25th May 2020 8:17am |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1614 |
I recently used Aquasteel on a 109 chassis which was in very good condition apart from some areas of a light rusting. I used a rotary wire brush on the rusted areas then followed up with the Aquasteel which turned the rusted areas a dark blue/black tough conversion coating which is ideal for further painting.
25th May 2020 9:24am |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 204 |
I have just finished applying this to my 90 as part of a suspension and brakes refurbish, very easy to apply as it goes on white in color then turns black after a few minutes so you can see where you have missed,
2.5 ltrs did all of my 90 with one coat just need to decide on a topcoat now. Here is a couple of after pictures Click image to enlarge Click image to enlarge Click image to enlarge This is before Click image to enlarge Click image to enlarge |
25th May 2020 10:07am |
I am thinking the same for mine. Just can't decide if I put red oxide on first or straight to Dinatrol. I think if there is any chance of the red oxide peeling then it is better not putting it on! Rust forms where water sits and water sits behind peeling paint!
25th May 2020 12:25pm |
