Home > Technical > Air con condenser |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
They only come complete with surround and fan. I got a britpart (spit) one years ago, and it looked exactly the same as original, fitted great, worked and lasted.
Could you get yours record like they do with rads? |
20th May 2020 4:48pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 541 |
There doesn’t seem to be an aftermarket source for these, even the britpart item is OEM.
Also because the Defender has finished production the price seems to have gone up!As I think it is unique to the Defender. I’m not sure if you could make something else fit. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
20th May 2020 7:38pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2082 |
They cost £420. No one else makes one. You cant make another fit without replacing all the AC pipe work.
Allisport considered one but never made it. Instagram @defender_ventures Empire Tuning - Agent |
20th May 2020 8:00pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
Oh.
Thanks for replies. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
20th May 2020 10:42pm |
I was just as down when my condensor totally failed a few years ago. They are so brittle and thin you cant even find take off or scrapped ones. I can say after i replaced it the AC now stays in for at least 8 months and is considerably colder. So well worth it.
Just got to find the other pin leak.... Instagram @defender_ventures Empire Tuning - Agent |
20th May 2020 11:06pm |
Ever since replacing mine I’ve had a fine mesh behind the grill, to save paying out again.
21st May 2020 8:09am |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
Speak to Robin at Duckworth Parts. (Brilliant service)
He’s got a few take off condensers. Replaced mine this morning, all gassed up and 🥶! |
21st May 2020 1:50pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
Mine has lost most of its fins and is held together with cable ties - they seem to be ultra vulnerable to salt and vaporise in a few short years. Whenever I go through deep water I end up with a festoon of unfolded aluminum fin hanging down from behind the grille. It still works though which makes me loath to replace it but don't want to dump the gas because I'm too tight to bow to the inevitable. I think it's a job for this summer.
21st May 2020 2:03pm |
New one ordered, thanks everyone. Cheers
22nd May 2020 8:33pm |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1014 |
Do you mind me asking where you got yours from & at what cost? Ours is held together with cable ties & needs replacing sooner rather than later.
25th May 2020 4:05pm |
Brookwells, Bovey tracy POC - Justin Cheers
25th May 2020 7:21pm |
26th May 2020 8:02am |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2075 |
Hi all
anyone found a more reasonable pricing for a condenser ? LR025985 The only ones I have found are still in the £400 range ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
19th May 2021 10:39am |
Interested in one also Gary, ours is about shot.
19th May 2021 11:09am |
