Home > Td5 > Coolant plug leak |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
Yes had this with my first Td5. Removed it and fitted new plug. Was fine after that.
5th May 2020 11:06pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16933 |
It's a very common Td5 problem.
6th May 2020 7:17am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Time to replace it. I know off some td5's of which a plug failed on the highway and that was the end off the engine. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
6th May 2020 6:00pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
Can I just remove it and apply sealing compound and refit?
10th May 2020 9:59pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
11th May 2020 12:15am |
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 |
It's a sub £15 part - I'd personally replace with a new one - as has been said, failure can be catastrophic.
LCM100170 is the part number |
11th May 2020 12:55am |
I’ve found the plug online but it’s just a plain plug, so I’m still going to have to use some form of sealant before I fit it, so why replace it when it’s the seal that’s gone? Agreed it’s all of £15 but In 20 years of being a heating engineer I’ve never seen a plug fail only the seals
11th May 2020 3:37pm |
