Home > Technical > Anybody recognise this rubber part |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
It looks like the rubber mounting between a rear bench seat and the tub capping. The seat back of the bench is bolted to the capping and the bolt passes through that rubber. It does on mine and they are Factory fitted. 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI |
4th May 2020 3:28pm |
beardiedog Member Since: 01 Aug 2019 Location: Northampton Posts: 27 |
Goo call I took the seats out a while ago so maybe it came out as part of that little job https://www.lrworkshop.com/diagrams/land-r...ench_53668
4th May 2020 3:36pm |
That’s the 1 - item 14 on the diagram 2017 Range Rover L405 Vogue SE V8 Diesel #16
4th May 2020 6:51pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3628 |
Hell of a spot! Well done that man! |
4th May 2020 7:18pm |
