Home > Puma (Tdci) > Immobiliser woes? Engine won't start - What should I check?
Chopperone
Hi
Some advice please.
I have a 2007 Tdci 2.4 with Central locking & two alarm fobs.
The vehicle battery is 18 months old.
Last week I went to move the vehicle which I hadn't used for about 3 weeks & it wouldn't start so I recharged battery & moved it out the garage - left it running for 5 mins & switched off to do my jobs.
One of the jobs entailed disconnecting the battery for a few minutes.
Once completed I went to start it & it wouldn't start & alarm sounded.
Tried a number of times & I thought the battery had gone down again.
I recharged it overnight. I also changed the battery in the alarm fob.
The alarm fob does not unlock/lock the vehicle. The alarm/immobilise lights are not illuminated at all.
So far I have tried pressing the fob repeatedly , I have disconnected battery & left off for 1/2hr. I have tried touching +ive to -ive terminals to "re-set" ; all to no avail.
I have read through various posts here. I don't have a Nanocom.
I have checked fuses & all appear to be in order.
What's my next move please?
Guy May your life be like toilet paper ; long & useful.
Post #824390 10th Apr 2020 12:14pm
Chopperone
Issue resolved !
Fuse 1 had blown & it blew again - not sure why. I replaced it & starting checking door switches. I then decided to RTFM & then applied some logic I have the alarm /immobiliser & C/L all working and the vehicle runs Very Happy
No where to go/not allowed to go anywhere. Still at least I can move it out of the yard.
Stay safe folks
Post #824395 10th Apr 2020 1:45pm
jst
Top result. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #824405 10th Apr 2020 3:07pm
dorsetsmith
Fuse 1 is ABS unit Question
Post #824440 10th Apr 2020 6:32pm
Chopperone
Unfortunately l spoke too soon.
I replaced the 20 amp fuse in position 1 under the driver’s seat.( marked central locking).
I have Mazda seats in my 90 so not exactly a 2 minute job to access the fuse box.
Then reset alarm & tested - everything ok.
Put seats back in / quick test & drove up my drive & then put back in garage; reset alarm & it popped the fuse,alarm goes off & it won’t start Big Cry
What l don’t understand is that l didn’t do anything anywhere near the C/L When l did the few jobs the other day.
I can only assume that there is a short somewhere in the C/L circuit which is causing the problem.
Any known areas where l should start looking?
Thanks
Post #824487 10th Apr 2020 9:47pm
jst
Door gaps where wire passes through. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #824488 10th Apr 2020 9:54pm
jst
If it was cl surely it would just not lock that door with failed wiring. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #824489 10th Apr 2020 9:55pm
dorsetsmith
You mean Fuse 7 feeds the battery voltage input pin 25 gray plug on the alarm unit
also feeds door locking output on the alarm unit green plug pin 3-2
Good place to start Central locking wiring
Id start with door to a pliller rubber and wiring
Post #824511 11th Apr 2020 6:28am
Chopperone
Thanks for everyones input so far.
I am confused about FUSE 7.
I have 2 x fuse locations in my 2007 90.
One under the steering column & one under the driver’s seat.
Under the driver’s seat there is a 20 amp fuse in the first position ; it is marked C/L ( nothing else) this is the fuse that blows.
There is no reference to fuse 7.
What am l missing?
I will have another good look in the next few days to try & solve this
Thanks
Post #824682 11th Apr 2020 10:17pm
dorsetsmith
This will keep you busy
https://1drv.ms/b/s!AtZSoWFHDgnGkGkrFWcZsRtsH3Dp?e=5L8B2W
https://1drv.ms/b/s!AtZSoWFHDgnGhDbxYedTopmyd1rA?e=a7MCOv
Post #824717 12th Apr 2020 7:58am
Chopperone
Hi
Thanks Dorset.
I now understand
It is Fuse 7 that blows.
So l need to trace where the wiring goes to that fuse.......
Thanks
Post #824718 12th Apr 2020 8:05am
dorsetsmith
And just so you can find think from drawing
https://1drv.ms/b/s!AtZSoWFHDgnGjECIf_wOfqrjegKe?e=kEfY0P
Post #824722 12th Apr 2020 8:48am
thompo
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Hi everyone i had problems with central locking on my puma ;i replaced my radio and sorted central locking out broken wire in door pillow behind passenger seat i had dissconected the battery,but tried everything it would not start i called a man that can it took him five minutes .He took the key fob away from the vehicle removed the battery from it pressed the buttons on the fob a few times replaced the battery pointed it at the car locked and unlocked it jumped in and it started.i hope you find this of help.
Post #825887 16th Apr 2020 9:12pm
Finchy13
United Kingdom 2013 Defender 90 Puma 2.2 HT Firenze Red
I had a similar problem when the battery died on my puma. Tried to start it after charging the battery but it wouldn't crank or lock/unlock from the fob. Had a blown fuse, can't remember which, replaced it and still no joy. Had to get a bloke out to reprogram the 10AS unit as its all too common for it to loose its coding...
Post #825898 16th Apr 2020 9:55pm
ZeDefender
Finchy - I had the same problem. Problem was I was in a psychiatric hospital car park and everything I tried set the alarm off. Eventually, I was politely asked to have it towed Embarassed Laughing Tell someone you love them today because life is short.
Post #825928 17th Apr 2020 6:27am
