Home > For Sale & Wanted > [For Sale] Genuine 12S Towing Electric Kit for 110 & 12N
rallysteve
Hi all,
I bought this kit ages ago with the intention of fitting to my 110 but i no longer require it.
This is the genuine kit for TD5 110 and should also fit some TDCi vehicles and can easily be adapted for 300Tdi.
It connects directly to the battery via two cables. There are two relays and a volt sensing relay which fit in the battery box. Strangely, although it plugs into the reverse light switch (for the ignition live) it does not pick up the reverse light feed from here. The VSR only switches the two ignition live feeds on when the engine is running rather than just the ignition on
The cable loom runs right to the back where it also plugs into the two spade connectors on the original loom near the grey multiplug for the 12N circuits where it picks up the constant 12v feed and reverse light feed. The socket is a genuine LR one.
The kit (STC50324) can be seen here https://rimmerbros.com/Item--i-STC50324 . Note: I don't have the mounting tabs for the relay holders or the metal bracket that holds the socket. The VSR has also been modified to have an adjuster so you can set the cut in/out voltage to suit your setup.
Think £55 posted is fair. I won't be able to send until after the current lockdown situation is over but happy to hang onto it without any deposit for someone who is interested.
I have a copy of the fitting instructions i can include too.
I also have the genuine LR 12N socket to go with it (some wiring still on it but i have used the grey connector for my 13pin setup).
Cheers Steve
[/list] 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #823364 4th Apr 2020 9:23pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
PM sent
Post #823376 4th Apr 2020 10:26pm
rallysteve
Still Available 02' 110 TD5 Double Cab Rebuild Thread
Post #823616 6th Apr 2020 8:54am
rallysteve
Bump £45 posted or £40 collected.
Cheers,
Post #838862 22nd Jun 2020 11:37am
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
PM Sent!
Very Happy 1984 90 V8 puma want to be.
Post #839060 23rd Jun 2020 8:14am
rallysteve
Now sold,
Thanks Simon Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #839627 25th Jun 2020 1:27pm
90GTR
2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
Sorry to bump this... but where did you get a replacement towing electric socket cap (the white part)? Mine has gone missing
Post #840061 27th Jun 2020 5:06pm
