Home > Wheels & Tyres > BF Goodrich KM3 MT |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2063 |
What's the issue that stops Blindo's on a balance machine??
1st Mar 2020 6:50pm |
They look far further out than the ET would have you think, are they the std 235 tyres or a 265??
1st Mar 2020 8:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16983 |
255/85 R 16
It's also possible that I bought ET0 Blindos, I really can't remember because it was so long ago! I'll see if I can see any markings on the back of the spare. |
1st Mar 2020 9:03pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 301 |
Danny Headlamp guards are eBay eBay Item No. 361460572892[/quote]
1st Mar 2020 9:09pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19708 |
Looks good Blackwolf - Always admired your 110. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
1st Mar 2020 9:13pm |
EVdV Member Since: 26 Nov 2017 Location: Vosselaar Posts: 53 |
I'm totally torn between 255/85 and 285/75 km3's.
But now having seen 255 on a 7' wheel I doubt they will fit good on my 8' wheels. Anyone gone from 255 to 285? |
2nd Mar 2020 12:50pm |
I went from 285 to 255, mainly because I like to open the window without filling the interior with mud, but also because the 285s are very susceptible to road surface phenomena and tramlining.
I cannot see myself going back to 285s. |
2nd Mar 2020 2:54pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
Going to be replacing the 7.50x16 Michelin XZL’s on my Defender with KM3’s I think.
Has got the stock Ex-mod Wolf wheels on so do I replace with 7.50 x 16 or go metric with 235/85/16 ? not after wider tyres really, plus the spare is on the bonnet so no extra weight up there is a bonus! |
4th Mar 2020 2:39pm |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 |
How many miles did you put on the KM2’s before changing them? Mostly road miles? Thanks Mark |
4th Mar 2020 10:15pm |
Around 80k miles on the KM2s, they had about 8mm of tread left on them. The original KMs (KM1s I guess) lasted for 100k.
4th Mar 2020 10:22pm |
Thanks
4th Mar 2020 10:27pm |
I’ve spent far too many hours researching which size tyres to fit, 7.50r16 or 235/85/16 ?
Now after seeing many with 255/85/16 maybe I should just go with them! Would they fit my Wolf rims ok, what are the advantages and disadvantages of fitting them? Thanks for any info. |
8th Mar 2020 9:23am |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
Yes they will fit fine, they give you more ground clearance and raises the gearing slightly / your speedo is likely to read accurate as they normally under read.
Piccy to show size difference Click image to enlarge 2017 Range Rover L405 Vogue SE V8 Diesel #16 Land Rover 110 300 TDI |
8th Mar 2020 10:36am |
Thanks, that’s some size difference. Is that against a 235/85/16 ?
Any rubbing in the arches? Steering stops need adjusting? Loss of power with a 300tdi? Sorry for all the questions but having to buy 5 is a big cost and I don’t want to get it wrong!! |
8th Mar 2020 1:43pm |
