Home > Wheels & Tyres > General Grabber X3 285/75R16 - Any lift required on my 110? |
sconie Member Since: 10 Jan 2020 Location: Paisley Posts: 50 |
Sorry for another tyre post but I am finding mixed answers via the search! I've been offered an upgrade to the General Grabber X3 as the tyres I ordered are out of stock for a few weeks. I'm looking for a definitive answer to whether these tyres fitted to 16x8 modular with an Offset : ET + 8mm would need a lift?
if so I can ask for a smaller tyre fitted. If so what size would you recommend? https://www.paddockspares.com/285-75r16-ge...-only.html Thanks again in advance. Sconie |
14th Feb 2020 11:26am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1732 |
ditto.
17th Feb 2020 12:24pm |
Brilliant thanks for the replies guys 👍
17th Feb 2020 1:56pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7741 |
They will fit without a lift and for gentle off roading and tarmac will be fine. You may find tyres rub return edge on rear mud guards on full rear axle flex though. Non arb. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
17th Feb 2020 4:42pm |
Click image to enlarge Got my wheels and tyres fitted today, love the look now. They do however catch on full lock so I'll need to study forum posts as to how I adjust the steering stops. |
20th Feb 2020 3:02pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2537 |
Click image to enlarge sconie It depends on what you are indending to do with your truck. On my previous 110 I had 255/75/16's. So same height, a little narrower. I also had a two inch lift. The picture show the tyre snuffed into the wheel well. A wider 285 would have rubbed on the inner wheel arch and may have pushed out the outer wheel arch. A 285 also drags along the sides of ruts more than the 255. Again it depends what you are planning to use your truck for. Good luck |
20th Feb 2020 4:23pm |
