Home > Puma (Tdci) > Help! I Need a Puma 2.2 under seat fuse box layout |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 993 |
sorry, dont have it with me but there should be a label under the lid.
If no one else has the layout, you could test them all; multimeter? One of the 60A is between battery and ignition switch. Then https://www.lrworkshop.com/diagrams/land-r...ca_2.2tdci |
2nd Feb 2020 5:03pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 315 |
I think ignition fuse is FL1. Starter motor fuse is F3.
There's a fuse layout diagram in this thread https://www.defender2.net/forum/post299431.html Relay diagram here also https://www.defender2.net/forum/post385404.html Hope you get it sorted. |
2nd Feb 2020 5:05pm |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 226 |
Thank you JPE. It was ideed FL1. up and running again..
2nd Feb 2020 5:52pm |
60 amp fuse link, what over loaded this 60 amp fuse
2nd Feb 2020 6:44pm |
Hi
Couldn’t turn the key. Managed to get the ignition / lock off without cutting the clamp. I drilled a 4 mm hole and cut M5 treat in the security bolts (see picture). Screwed in a bolt and got the original bolts out. I was happy as hell. But when I took the cables off I got some sparks when it came to the steering column. This blew the 60A fuse. Click image to enlarge |
2nd Feb 2020 7:04pm |
Ok
2nd Feb 2020 8:09pm |
