Home > Maintenance & Modifications > Rear shock absorbers
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
I know this is a subject that has many threads and I have read through a few of them (honest) but I just wanted some clarification.
I have a 2010 90 HT with 86k miles and it has a thudding, knocking noise from the rear load area. I have a bit of movement in the door but I don't think it is the cause.
I have play in upper and lower shock bushes so am going to start there but my question is - will upgrading the shocks help the crashy ride from the rear.
I'm aware that for the most part, changing the springs is the best option but has anyone changed their shocks and had a decent change in the ride?
Ps, is there any other thudding causes I may have overlooked?
Thanks
Post #810686 17th Jan 2020 11:54am
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
My 90 SW had a new suspension setup completed last month... I think the most noticeable changes were actually from the shocks (Fox 2 adjustable) and the anti roll bar, although I went for same height progressive springs I didn't particularly notice a massive difference from them. I had these changes done in different stages so I could try things out and get a feel for what I wanted.
I'm over the moon with my final setup and although it's not one of the cheapest offerings I wouldn't hesitate to do it all over again if I had to.
(Other mods on top of the above which were fitted were the Gwyn Lewis Sumo Bars, and Old Man Emu steering damper and Gwyn Lewis turrets which I'm sure impact the over all ride as well)
Post #810687 17th Jan 2020 12:08pm
Most likely caused purely by the damper bushes, the lowers tend to go first and are easier to replace. The uppers are a bit of a pain. Diesel$ Live$ Matter. β›½οΈπŸ›’οΈπŸ‘¨β€πŸ”§πŸ§°βš™οΈ RED, WHITE & BOOST! πŸ‡¬πŸ‡§
Post #810688 17th Jan 2020 12:24pm
IGP
Recently replaced all my dampers and springs with standard ones. I also fitted spring isolators top and bottom of all the springs. Made a hsge difference to the ride, no more crashing and banging like before.
HTH
Ivan
Post #810706 17th Jan 2020 2:36pm
dorsetsmith
Post #810708 17th Jan 2020 2:41pm
SimonDavies
Thats refreshing to hear. I'm thinking that at 86k miles, my original dampers must be pretty tired so would like to renew them. The fox shocks that you run, are they with the remote Res?
Post #810741 17th Jan 2020 6:54pm
SimonDavies
I'm hoping that is the cause. Based on the mileage I would like to replace them complete, especially if there will be a noticeable difference in the ride.
Post #810742 17th Jan 2020 6:56pm
SimonDavies
HTH
Ivan
What mileage was your Def when you replaced?
Post #810743 17th Jan 2020 6:56pm
I have the same set up as IGP.
Or at least similar.
Genuine springs, genuine castellated isolators top and bottom on the springs.
Genuine shocks, and bushes.
Just thought I’d post up here to mention the set up works well. πŸ‘πŸ» Diesel$ Live$ Matter. β›½οΈπŸ›’οΈπŸ‘¨β€πŸ”§πŸ§°βš™οΈ RED, WHITE & BOOST! πŸ‡¬πŸ‡§
Post #810752 17th Jan 2020 7:49pm
SimonDavies
Thank you. Is your defender a 90 HT also?
Post #810771 17th Jan 2020 9:27pm
Yes it is, I fitted Genuine 90 HT springs myself. I replaced the spring seats as well whilst at it.
On a 90 you can fit the castellated isolators top and bottom all around like I have but on a 110 I believe you can on the front but on the rear you can only use the wrap around spring isolator.
On the rear I fitted the wrap around isolator as well. On top of the castellated ones but if I did it again I’d leave that out as the rear sits a tiny bit higher than it need have been really.
Very happy with this set up, it has eliminated a lot of extra road noise and vibrations. Especially on rough unsurfaced routes like Byways and things like that.
But it doesn’t feel at all vague either.
It will also give you a minor lift, not much but a bit and no other modifications needed either. Diesel$ Live$ Matter. β›½οΈπŸ›’οΈπŸ‘¨β€πŸ”§πŸ§°βš™οΈ RED, WHITE & BOOST! πŸ‡¬πŸ‡§
Post #810783 17th Jan 2020 10:39pm
MK
I am going back to std, non N filled OEM shocks. Puma 110" SW
Post #810789 17th Jan 2020 11:10pm
X4CAC
Yep those are the ones, probably a bit over kill on all four corners but having driven another 90 with the same setup it was an easy decision
Post #810895 18th Jan 2020 8:19pm
IGP
SimonDavies wrote:
HTH
Ivan
Mine has done about 190,000 miles. However, when I purchased the car it had HD springs with a 2" lift and gas dampers. It was a very hard ride.
HTH
Ivan
Post #811135 20th Jan 2020 11:23am
