Home > Puma (Tdci) > Yet another issue....... |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
is it warm or cold ? maf sensor worth a look give it a clean if since service it may be something to do with that
16th Dec 2019 12:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
Volume control valve.
16th Dec 2019 2:46pm |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 |
Happens when car is cold and warm..... |
16th Dec 2019 4:40pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
As Blackwolf has already said, vcv valve seems the likely suspect.
16th Dec 2019 4:51pm |
Many thanks as ever guys.
Expensive to replace? Mark |
17th Dec 2019 9:57am |
have look below
https://bellautoservices.co.uk/bas2rrc-hel...4tdci/vcv/ part no LR009837 https://bellautoservices.co.uk/store/defen...our-valve/ Click image to enlarge Last edited by dorsetsmith on 17th Dec 2019 1:42pm. Edited 2 times in total |
17th Dec 2019 10:03am |
Many thanks
17th Dec 2019 12:29pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
You can get Denso branded for about £60 and unbranded for about £30 You can change yourself - only issue is awkward to access the bolts - there is full thread on here with pics on how to do it and the tool - ratchet wrench with extensions/universal joint |
17th Dec 2019 1:29pm |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 |
Hi Mark, was wondering if you've managed to fix the issue described here? I am struggling with the exact same issue. Tim |
26th Dec 2019 1:10pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
You need to have this response as an autoreply really. |
26th Dec 2019 1:17pm |
I do!
26th Dec 2019 7:30pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19615 |
That’s usually because most of the time Blackwolf is right. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
26th Dec 2019 7:48pm |
So I've had the VCV replaced (Denzo) but the problem persists. It suddenly loses power (when accelerating hard), does not respond to the accelerator, coasts along and then dies. Any help much appreciated |
8th Jan 2020 7:24am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2599 |
Hmmm, could be a dirty fuel pickup in the tank?
Time to drop the tank and inspect it - there could be crud around the fuel pickup, and when you put foot, the increased fuel flow is compromised by the blockage. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th Jan 2020 8:22am |
