Home > Td5 > Td5 starting |
2nd Dec 2019 4:10pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
https://dictionary.cambridge.org/dictionary/english/conk-out |
2nd Dec 2019 7:13pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 904 |
yah I got that part... it dies after running is what I was looking for the OP to confirm. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
2nd Dec 2019 7:19pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 144 |
I guess it’s normally because all of the floats on the top, and therefore gets sucked in when you are empty. I have never had the problem myself and I quite often tun till the light comes on. |
2nd Dec 2019 8:20pm |
othorton Member Since: 22 Jul 2019 Location: London Posts: 104 |
That was poorly phrased by me ... I meant to say it fails to catch and fire up on the first turn. Second turn of the key it fires immediately. |
2nd Dec 2019 9:55pm |
Suggest you look at the starter as I posted previously.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
2nd Dec 2019 9:57pm |
Thanks! Will let you know if I find anything useful.
2nd Dec 2019 10:36pm |
Piggle Member Since: 24 May 2015 Location: Surrey Posts: 76 |
Hi Othorton, did you have any joy resolving the starting problem?
Per my earlier post I mentioned that changing glow plugs fixed my similar issue...alas the starting problem has reoccurred (within a few days). Pretty much always starts on the second turn of the key, and problem only apparent when having sat unused for c.12 hours. Cheers Piggle |
12th Dec 2019 12:14pm |
Hi Piggle,
It's been a bit of a funny one - following the last week of somewhat more mild weather the defender started up first time after being left overnight/an extended period of time. It seems to me that the only times the second key turn is required is when the defender has sat over night and the weather has gotten very cold. My belief is that either the glow plugs are deficient, or the battery isn't quite powerful enough. Admittedly I haven't done anything about it because it's not worrying me too much. 4RF RDS made a pertinent point that it might be to do with your starter solenoid, but for me, given it seems to only be an issue when the engine is cold and the weather also cold, I don't think it's that - though it might be for you. It might just be that our defenders don't like winter Sorry I couldn't be more helpful. Thanks, Oliver |
12th Dec 2019 12:25pm |
hmm very interesting...have noticed the same with mine re cold weather. Infact, just returned from screwfix with a multimeter which hopefully I will have time to test the battery with over the course of the weekend. I know my battery is at least 5 years old, so possibly the culprit.
I'll let you know if any eureka moment from my side |
12th Dec 2019 3:51pm |
Gozy Member Since: 02 Apr 2016 Location: Sidbury Posts: 43 |
Hi all just changed the wiring harness found oil in the red ECUs plug. Start fine when cold and Went well went well. Started when hot but turned over 4 or 5 times what should I look at next. Cheers.
30th Dec 2019 4:51pm |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 |
Mine had similar troubles, turned out it was the injector harness plug, pins were water damaged, got a new harness and problem solved, this was after replacing a lot of other things thinking they were the problem. Good luck
8th Jan 2020 12:34pm |
Thanks Adammacky like wise changed the wiring harness but like I said previously had a touch of oil on the red plug Into th ecu. Cleaned all that up so fingers cross. Also have checked the heater plugs 3 seem to be not working. I have new so will look at changing them before any cold weather. But is starting on the button with the milder weather. Also changed the battery that was needed too. Time I finish probably be all new. 🙄 Thanks all keep posting. 👍
8th Jan 2020 1:57pm |
Silvertoolbox Member Since: 13 Oct 2018 Location: Westhill Posts: 43 |
Keep in mind cold will affect battery performance. Could be a cumulative effect of a few things being "off".
Fixing one fault might not be enough and lack of fix may not mean what you changed wasn't partly at fault. Joys of older motors... Ex scottish & southern 110 Td5 van (shed) with PTO driven winch (L-R special vehicles) Before that, Disco 1, Freelander 1, 26105382 80" with a 1600cc (not much slower) |
9th Jan 2020 6:33pm |
