Home > Wheels & Tyres > Modifications to fit wolf wheels |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16954 |
No modifications of any kind are required.
There is an internet myth that you need to fit longer studs, but you do not. All you will need is to ensure that you get a set of the correct wheel nuts for steel wheels, as they are different to those for alloys. it is an easy job - jack up, remove alloy wheel, fit steel wheel, lower jack! No costs involved other than the new wheels, tyres and nuts. |
18th Nov 2019 12:00pm |
And if you're buying new wheel nuts, I can highly recommend Wrington Engineering blackened, closed end ones:
Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
18th Nov 2019 1:07pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2058 |
whats the spec of the 2x wheel nuts?? i believe they are M16x1.5mm thread pitch
do they need a flat nut or tapered for the steel wheels?? |
18th Nov 2019 1:56pm |
From Series III onwards, they're M16x1.5mm and they're tapered. Darren
18th Nov 2019 2:11pm |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 |
Hi LandRoverAnorak, those wheels look amazing.
I just phoned my local LR dealer and they are quoting £140.40 inc vat per wheel. Ouch. What size of tyres have you got on them? Is that 235/85/R16? cheers |
18th Nov 2019 3:17pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
I fitted extended wheel studs, as the original only studs only extended half way thru' the wheel nuts, which I personally wasn't happy with. The studs are now too long. Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Nov 2019 3:41pm |
Thanks Yes, they're 235/85 General Grabber AT3's. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
18th Nov 2019 10:07pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2238 |
Damn you. Piqued my interested big time and they're out of stock > 110 XS Double Cab > Instagram @simonlanemind |
19th Nov 2019 6:18am |
Sorry Darren
19th Nov 2019 9:32am |
Hey Darren, I see from a previous post your wolfs are from Terrafirma..... You happy with them? Quality ok? Seems a fraction of the price of LR ones. I'm guessing at 1500kg they will be up to off-roading???
cheers |
19th Nov 2019 12:30pm |
They are absolutely fine and the 1500kgs load rating is still stronger than virtually every other LR wheel. Darren
19th Nov 2019 1:34pm |
hxk494 Member Since: 29 Apr 2013 Location: Edinburgh Posts: 237 |
Hank, If you're still looking for closed end black nuts I've got a set of 23 I bought earlier in the year. They've done around 4000 miles to spain and back but have gone back to alloys so now surplus to requirements. Looking for £50 for them, were £69 new. 1996 300Tdi Defender 110 |
30th Nov 2019 1:43pm |
Shop around on OEM rims, there's a good reason they are rated at 2,200kg ; ask yourself the question why a pattern wheel maker down rates their's to only 68% of OEM... |
30th Nov 2019 6:46pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
For the small additional cost of genuine which can be bought quite reasonably if you look around, I wouldn’t entertain fake wolfs - or any fake / copy wheels - the small extra cost for piece of mind is worth the tiny extra cost - plus fake wheels in an accident could be an issue with insurance unless you notify them and get cover agreed - it’s simply not worth the risk finding you are not covered and end up with a liability bill for the rest of your life or losing your home over. 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI |
30th Nov 2019 7:20pm |
