Home > Series Land Rovers > Shroppy's Series 1 V8 - 1958 88" 4x2 |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Looking forward to hearing and seeing this around the Shropshire Hills Just because you're offended doesn't mean you're right.
14th Nov 2019 3:06pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
Awesome 1951 80" S1 2.0
14th Nov 2019 9:38pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10547 |
Great thread and a great fabricator, watching out for the next instalment
Glad all is ok with your op and your healing well 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
14th Nov 2019 10:12pm |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 855 |
Thanks all, will hopefully have an update this week once the steering bits arrive.
A friend ran the same setup inc 80" rear prop in his FreeRanger (no prizes for guessing what it is) for a few years in hill climbs etc without any problems so I'm hoping it'll be up to it. I'll try and get away with the longest prop I can for the rear, but the Salisbury will already knock 2" ish off the length. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
17th Nov 2019 11:13am |
Well an update / change of direction....
In the end it took me much longer to get back a reasonable starter of fitness than expected. Turns out you're tired all the time and the very nice consultant tells you politely that you're an d**k for doing to much and not resting. Anyway not all bad news, it's given me plenty of time to think things over. In short, 110 will be sold, 130 (127) purchased and the 88" kept slightly more original. Here's my logic; The 127 (1986) is a factory 3.5 V8 and the 4.6 would be much more usable in a 130 than an 88" S1, power steering, coil springs n that! I found the correct 4x2 front axle casing and stub axles that the 88" would have originally been fitted with and as very few 4x2 models were ever built (probably because they were naff) it seemed a great shame not to use them. Click image to enlarge So the 3.5 V8 from the 130 will go in the 88" with a S2/3 gearbox and the 4.6 V8 and R380 will go in the 130 (separate build thread on its way). All in all a simpler and probably safer way forward. More updates to follow as soon as I've finished helping Dad with his projects! 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
6th Jan 2020 9:10pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1205 |
Nice work. Good plan to keep it 4x2. When I did mine back in the early 00's I thought about a v8. I wish I had now. Anyway here's mine.............
Click image to enlarge1july by Richard Holmes, on Flickr Click image to enlarge1116 by Richard Holmes, on Flickr 2010 XS USW 1957 Series One 88 diesel 1958 Series One 88 4x2 |
6th Jan 2020 9:57pm |
Lovely 4x2! Mine is '235 FUV' it seems there's no pattern to the issuing of the 'FUV' plates from what I've found so far. 1985 127 V8 Build Thread
6th Jan 2020 10:05pm |
Thanks. Ill be following your build with interest then. Yes random would be a a fair description. Do you still have the military ID? Mine was 07 CE 27 and somehow the plate was still affixed to the bulkhead. 2010 XS USW
6th Jan 2020 10:14pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 694 |
Here’s my 4x2, I also considered a V8 when I first rebuilt it ten years ago but
Click image to enlarge I was given a 2.5 with an ACR SU conversion. I recently added an ACR branch manifold with a custom built exhaust. I’m now having bad thoughts about sending my spare engine to ACR to be bored out to 2.8l with stage 2, 1:9 head..... Click image to enlarge Mine was converted to 4x4 before I owned it and I’ve no desire to revert😊 |
6th Jan 2020 10:55pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1614 |
Great thread, enjoying it very much.
6th Jan 2020 11:58pm |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1365 |
A friend of mine (now sadly deceased) had two 4x2 Series Ones, both converted to 4x4, but both with FUV registration numbers. Euro-Leafing to infinity and beyond.....
9th Jan 2020 7:30pm |
