Home > Tdi > Will a Td5 Transfer Case bolt straight into a 300Tdi? |
RobM Member Since: 06 Jul 2015 Location: Brisbane Posts: 43 |
Guys...
I'm looking to buy a TC out of a Td5 Defender but I'm a little bit unsure if it will simply bolt straight in without any mods. I know the Td5's have a electronic speedo whereas the 300Tdi's don't - will this be an issue? Rob Cheers..... Rob 1995 Defender Tdi 110Wgn 1996 LR Discovery Tdi300 (A) 2009 Defender PUMA 110Wgn My TRPS: Rob's WikiLoc Trips |
28th Oct 2019 6:16am |
Td5's have a electronic speedo whereas the 300Tdi's don't - will this be an issue? No as Speedometer Transducer can be removed
then removing the transfer cases just make a note of there bolts are from as not all same length and go though in to the gear box and from gear in to transfer box not all blind hole or swap over the speedo on the dash to an electronic version and add the wiring and plug http://www.retroanaconda.com/landrover/200...tdi300tdi/ Last edited by dorsetsmith on 28th Oct 2019 11:52am. Edited 1 time in total |
28th Oct 2019 10:17am |
This sounds interesting... My speedo is terribly inaccurate so I like to know more about this mod ?? Cheers..... Rob 1995 Defender Tdi 110Wgn 1996 LR Discovery Tdi300 (A) 2009 Defender PUMA 110Wgn My TRPS: Rob's WikiLoc Trips |
28th Oct 2019 11:15am |
Thanks for the link -- reading it now Cheers..... Rob 1995 Defender Tdi 110Wgn 1996 LR Discovery Tdi300 (A) 2009 Defender PUMA 110Wgn My TRPS: Rob's WikiLoc Trips |
28th Oct 2019 11:17am |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 350 |
My 300Tdi came out standard with the electronic speedo. Very nice.
29th Oct 2019 4:37pm |
