Home > In Car Electronics > Econoseal Connectors - Disassembly |
Try something like this:
https://www.polevolt.co.uk/acatalog/Termin...-TT99.html There are cheaper out there, but I have found that these two tools have served me well over many years. |
12th Oct 2019 4:43pm |
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 |
I have the same tools as above, and they are good for the money but can be hit and miss sometimes. I have a selection of dental tools at my disposal, and they are some of the handiest yet oddest pieces of kit I have in the toolbox.
The econoseals can be a bit frustrating- can’t remember which side is which (female / male) but if you remove the yellow cover plates you will see slots above the terminals, using a flat thin blade type removal tool insert this to push the tang down and then remove the terminal. You may need to give it some vertical pressure to move the tang if it’s not playing game, but persevere and you’ll get there. Give the terminals an inspection when they are out, i had corrosion on my bulkhead connectors which led me to reterminate the lot. On reassembly give the seal some lubrication on insertion to help it slip on in (all innuendo’s on purpose). Enjoy. |
12th Oct 2019 5:07pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
I've managed to disassemble the connector following advice from Zippo - many thanks. I also did it without any specialist tools but thanks all the same Supacat. Defender 90XS SW
13th Oct 2019 12:27pm |
13th Oct 2019 1:31pm |
AlexSmith Member Since: 05 Sep 2013 Location: Arroio do Meio, RS Posts: 47 |
Same here! Had a problem on the rear flashlights today and had to remove the connector for cleaning. It took a long time and a lot of patience, but in the end they came out. Thanks! 2020: Defender 110 SW 300 Tdi 2004 Alpine White 2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray 2002-2005: Defender 90 CSW 300 Tdi Dark Green |
26th Mar 2023 2:45am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
Have got a few different terminal removal tools/kits but for econoseal I always just default to using a cheap scribe tool from toolstation:
https://www.toolstation.com/engineers-scriber/p76054 Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
26th Mar 2023 8:59am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
A safety pin works well on Econoseals, Multilocks, HM series, and many other types, where the terminals are located by a 'tang'
. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
26th Mar 2023 9:46am |
Makes sense! I ended up getting it apart by using a small piece of rigid wire, which is basically the same as this tool. 2020: Defender 110 SW 300 Tdi 2004 Alpine White 2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray 2002-2005: Defender 90 CSW 300 Tdi Dark Green |
26th Mar 2023 7:26pm |
