Home > Puma (Tdci) > Heated seat not working...
Cake
My drivers heated seat isn't warming up and the passenger side is.
The light comes on but that's about it.
Has anyone experienced this or have any ideas of some checks for connections or fuses?
Thanks
Post #454490 12th Sep 2015 6:09pm
K9F
Multimeter and check there's power going to it and check the resistance in comparison to the other seat to see if the element may be open circuit.
K9F wrote:
Each seat circuit has a heater element rated at about 14.4 watts at maximum current draw.
Each seat will draw only 10 amps each maximum, being protected by a single 20 amp fuse (fuse 33).
The maximum resistance value of the seat heater element would be approximately 1.2 ohms.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #454503 12th Sep 2015 7:09pm
RED-DOT
The multi plug under the seat is a weak point. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #454518 12th Sep 2015 7:51pm
AndyS
Pull the seat base off, they lift up at the front, you'll need to give it a swift tug. Then have a look at the cable that comes out of the bottom of the seat, I think it goes to a block connector somewhere along the line (but that's from memory so could be wrong (although it must be connected somewhere!)), make sure the cable hasn't been snagged from a previous seat removal. The cable doesn't seem quite long enough to put the seat anywhere out the way so it might have been dislodged from one end or another.
I'm not sure if the passenger and drivers seat is swoppable but I'd try that, see if the problem stays put or changes to the other seat.
Post #454519 12th Sep 2015 7:56pm
Cuthbert
Re: Heated seat not working...
My doctor would day that you were a very fortunate person.
He seems to have a lot of patients with a painful medical problem that he feels is accelerated by drivers heating up their nether regions.
Post #454539 12th Sep 2015 9:12pm
Cake
Thanks all for the great info.
I will remove the seat and take a look Smile
Hopefully an easy fix Smile
Will report back with my findings incase anyone else experiences the same thing
Post #454546 12th Sep 2015 9:53pm
Cake
Thanks all just a loose connection under the seat as stated and working now Smile
Thank you!
Post #454643 13th Sep 2015 12:08pm
AndyS
When I bought my one the salesman said owning a Defender is a way of life. I think that's what he meant, you'll be spending all your time fixing it. Very Happy
Glad it's sorted.
Post #454678 13th Sep 2015 3:05pm
Cake
Yes I have plenty of things I would like to do but keeping it sensible.
Job 1 done which was the seat heater. Some security in its way.
Next a service, then a polish, tidy a little carpet, remove the tow bar, replace some rusty bolts and that should be her 100%.
Going to get Her 100% perfect as standard and then next year move to the modifications - will keep it all sensible and nothing outrageous just LR accessories - well that's the plan.
Post #455064 14th Sep 2015 8:34pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Now winters upon us, there's a few things that need looking at that I swore I'd do before i needed them Laughing first one is my heated seats, they used to get really hot, now the passenger seat is just warm, and the drivers side doesn't work at all?
Questions
What controls the heating limit? Has it a thermostat connected somewhere?
And although I have supply to the drivers side coming in from the seat box it disappears up into the backrest (that doesn't work) but I could only test the seat connection which is dead? Does it daisy chain somehow, and how difficult is it to get to the backrest connection
Ta 2005 TD5 90 CSW XS
Post #576021 7th Nov 2016 12:50pm
Hall46
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
Got this issue on my 110. Doesn't seem to be any obvious snags on the wiring and the light is coming on for the seat which I believe means there is not a fuse blown. Does anybody have a circuit diagram for puma heated seats?
Post #737419 29th Oct 2018 6:53pm
dorsetsmith
Post #737425 29th Oct 2018 7:32pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Does anyone have this wiring diagram?
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion
Honda Benly CD200....Maroon ------------- Chausson 98.........7.5m of fun
Post #797422 9th Oct 2019 3:55pm
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
My ones work, but don’t come on that much and don’t get that warm?
Is this right, they are a bit disappointing?
Kevin
Post #800685 4th Nov 2019 12:36am
Clemmo
Thumbs Up ..thats right
just takes the edge off...very welcome when it's proper cold
Post #800697 4th Nov 2019 9:11am
