Home > Pictures & Video > drone |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
anyone use a Drone to record trips etc ,im after some info on which is best ,how hard are they to use
27th Sep 2019 4:44pm |
many thanks
27th Sep 2019 5:03pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4791 |
Hopefully I’m not breaking any forum rules
Give Paul or Beth who own https://www.hobbymounts.co.uk/shop/index.php?route=common/home They will be able to help you 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
27th Sep 2019 5:19pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2627 |
Yup I'm a big fan of them...
this is one I took a while back at work Click image to enlarge Here is my IG, plenty of drone shots https://www.instagram.com/liamldavison/ I have some stuff from Kielder but my youtube won't load currently but here are some screen shots Click image to enlarge Click image to enlarge Click image to enlarge |
27th Sep 2019 5:53pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3332 |
Just need to be aware of the regs and from next month all drones and pilots need to be registered with caa. https://dronesafe.uk/drone-code/
Main regs are: No flights within 150m of built up areas. Minimum 50m from anyone, including vehicles and buildings , not under your control Drone must be kept in line of sight of pilot (goggles and fpv only allowed with an observer maintaining line of sight). Avoid flight restriction zone around airports. Max height of 400ft. Also to avoid any trespass issues it's best to obtain the landowners permission for take off. |
28th Sep 2019 11:55am |
I was thinking of the mavic air anyone got one
1st Oct 2019 7:21pm |
Did you get hold of hobby mounts ok? 2015 HT XS 90
1st Oct 2019 7:26pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
I use the DJI Phantom 4 very very easy to use with 4K, obstacle avoidance, tracking and return to home feature etc
Only gripe is the size the Mavic is a bit smaller and also very good. 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
1st Oct 2019 8:30pm |
Craig-C Member Since: 25 Aug 2017 Location: Staffs Posts: 40 |
Very pleased with my mavic air. Easy to fly with most features of the bigger DJI drones but much smaller. Chose this to take out on my motorbike or even walking. Range is reduced but with new line of sight laws this is not a problem. It takes stunning 4k video and great photos. I chose the fly more pack which comes with 3 batteries which each last about 20 minutes.
Click image to enlarge Click image to enlarge FFRR TDV8 sold PUMA 90 :0[==]0: 90 TD5 CSW XS MX5 (NC) BMW 320 BMW 1200 GS Adventure SUZUKI HAYABUSA |
1st Oct 2019 8:45pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
I can highly recommend any of the DJI models.
I've had the pleasure of playing with a lot of DJI models for work and they're so easy to fly. You can pick them up second hand for a bargain as people always buy the best, then use them for a few hours. Get bored and sell on. |
1st Oct 2019 8:46pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
Hi there!
I usually use a Mavic Pro for my trips (and for work also). Not too expensive like inspire but more sturdy and long range compared with Mavic AIR Good piece of equipment: Very stable with wind and quite portable. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
1st Oct 2019 10:02pm |
Click image to enlarge A picture taken some days ago from the farm (you can see the Defender in the upper part) Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
2nd Oct 2019 12:32am |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 410 |
If you want a little project you can have a go at building one with all the gps functions and the advantage that if/when the rules come in ( they are delayed at the moment) you will fly in the home built category.
https://www.thingiverse.com/thing:3891175 |
2nd Oct 2019 7:26am |
some great shots
how tight are the rules on these going to be ? |
4th Oct 2019 5:25pm |
