Home > Tdi > Coolant system leak
JonJop
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
Coolant system leak
Hoping someone can help. The temp gauge shots up on my way back home tonight. I checked the coolant level once the engine had cooled to find the tank was empty. I filled it only to find water coming from the front, passenger side of the engine bay. The top and bottom radiator hoses seem fine, but I gave them a squeeze and you could hear water escaping from another pipe. I’ve taken a pic and hoping someone can help identify what it is. Many thanks.
Post #789921 1st Sep 2019 7:00pm
donmacn
Hi Jon,
Can you post your pic??
When my car did this, it was the hose between the heater and the cylinder head that had gone - but that's not too near the front.
If you can get someone else to put water in while you check where it's coming out, that might help.
( Edited - that pipe in the pic you put in your gallery is the power steering pump, so no coolant coming from there. But the water pump is just above that, and a likely source of a leak.) Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #789942 1st Sep 2019 8:40pm
JonJop
It’s coming from the bit circled in red
Post #789943 1st Sep 2019 8:42pm
donmacn
Our posts crossed. Yea, that's one of the pipes to the PAS pump, so while it looks wet - it's not leaking from there. Donald
in the past..
Post #789944 1st Sep 2019 8:45pm
donmacn
If the leak is showing there though, it could be a few things.
First and easiest, see if you can get a good look at all the hoses, check they are all intact, and that they are a good fit onto their mountings. Check the jubilee clips are intact.
Then, you could take the hoses off, and check the conditoin of the pipes/boss they fit on to. As it's aluminium, it does corrode.
Lastly - and the most hassle - you could be looking at the water pump gasket, or evn the P gasket between the engine block and the auxiliary mounting bracket.
This video would show that stuff more clearly. https://images.app.goo.gl/37W14M8YxbijyCgy7 Donald
in the past..
Post #789948 1st Sep 2019 8:55pm
JonJop
. It it looked almost certain that the water was bubbling from there when I squeezed the radiator pipe? Perhaps it’s the gasket between water pump and block?
Post #789955 1st Sep 2019 9:20pm
donmacn
That pipe definitely contains transmission fluid, for the power steering system I'm afraid.
Looking at the pic again you can see some water on the aux bracket, under the alternator, and evidence of dried up water runs which show that water's been running down there.
Like I said, neither gasket is especilly difficult - quite involved, in the sense that a few things need to be removed first, and then careful not to overtighten stuff on reassembly - but not that challenging really. I think I watched a few vids before tackling it, and read the wrkshop manual, just to get a clear picture of what was needed. If you're in there anyway, and it's not been done recently, I'd go for a new waterpump as well. It's not that expensive, and you'll have removed it anyway. Donald
in the past..
Post #789964 1st Sep 2019 9:48pm
JonJop
Great - thanks for the info
Post #789967 1st Sep 2019 9:50pm
donmacn
Happy to try and help.
Just to stress though, check the hoses/clips/joints first.
Unless it's really, really bad I'd expect leaking gaskets to 'leak' or weep, rather than pour out, so if it's a substantial leak, while the gasket might well be leaking too, the worst problem could be something easier to fix. Donald
in the past..
Post #789972 1st Sep 2019 10:02pm
JonJop
I put around 2 litres of water in the expansion tank and it was completely empty in less than a minute...
Post #789976 1st Sep 2019 10:11pm
donmacn
Wow. That's some leak - or it could mean that the system had emptied itself and your 2 litres was just refilling it.
Did you do this with the engine running? So that the water pump is adding pressure to the system, or with the engine off? If it's with the engine running that also means the fan could be spraying water around, confusing things.
I think you'll need to get someone else to add water while you have a close look at all the hoses and connections.
Don't know that I can suggest anything else really - there are so many parts and connections to the cooling system - but on the plus side most of them are visible, and water's a cheap and easy thing to pour in while you try and trace it. Donald
in the past..
Post #789983 1st Sep 2019 10:43pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Water pump or "P" gasket.
Post #790002 2nd Sep 2019 7:13am
JonJop
Thanks. Yes, added lots of water and was coming out as quickly as I was putting it in. Nothing though coming from the hoses. I’ll xhexk the pump and look to replace it along with the gaskets.
Post #790007 2nd Sep 2019 7:35am
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
If it's coming out as quickly as you say then it sounds like a hose off or badly split.
Post #790011 2nd Sep 2019 8:13am
JonJop
On another note, more worrying perhaps. The nut at the bottom right of the pics - it looks like there is a crack running across the block???
Post #790059 2nd Sep 2019 12:28pm
