Home > Tdi > What engine? |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
200tdi Just because you're offended doesn't mean you're right.
30th Aug 2019 3:06pm |
Michael Brindley Member Since: 07 May 2008 Location: stoke-on-trent Posts: 85 |
Many thanks thought it was but its been long time since i looked at one .Happy days when engine were simple.Wouldnt go back to one though.
30th Aug 2019 3:48pm |
Bows Member Since: 07 May 2012 Location: Wales Posts: 512 |
Fuel filter looks fresh, have a look at the oil filter down below the turbo, they soon look tatty if they haven’t been changed for a while and this is a good gauge when assuming maintenance schedules. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
30th Aug 2019 3:51pm |
Will check.Fluids in back look good though.
30th Aug 2019 3:55pm |
30th Aug 2019 4:13pm |
That looks like a little gem!!!! 2006 TD5110 station wagon
30th Aug 2019 5:10pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2062 |
Would think that may be the only time "drink & drive" are acceptable partners..........
30th Aug 2019 8:10pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4968 |
My dad or should I say my mum uses a 200 TDI for general use, and they have no trouble at all with him. Sounds like a transit or a tractor to me, but that's me. They love it to pieces! Not a bad engine to work on either, just make sure its serviced and your laughing! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
8th Sep 2019 4:53pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1785 |
200 tdi is lovely, love mine to bits, but I only potter around locally in mine as a rule . Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
8th Sep 2019 6:03pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
looks to be all there, could be a factory re-engine job, ie a complete kit, as the fan housing is even correct. Most retro fits don't even have a fan housing, or even have a belt driven fan, but use an electric one, as the engine is in a different place.
Having said that, I believe its a Disco lump, as the turbo is high up, I believe the Defender 200 tdi engine had a much lower turbo mounting. 'Volvo XC 70, taking the rough with the smooth’ |
8th Sep 2019 7:13pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6051 |
^^^ other way around wasn't it?
Defender the turbo was high up, idisco low down My factory new 200Tdi had the same turbo and (flimsy) heat shield as that one above. |
8th Sep 2019 8:15pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1205 |
Yes turbo high defender, low discovery 2010 XS USW
1957 Series One 88 diesel 1958 Series One 88 4x2 |
8th Sep 2019 8:18pm |
Ah, ok,, my bad. 'Volvo XC 70, taking the rough with the smooth’
8th Sep 2019 8:36pm |
