Home > Puma (Tdci) > Faulty EGR rework
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Faulty EGR rework
Hello, I have replaced EGR a while ago and have the faulty one laying around.
Is it possible to rework faulty EGR to have it as a spare backup part? I am not thinking about complete repair, rather a spare part that would allow me to reach home.
Cheers!
Janusz Janusz
www.yahodeville.com
Post #780757 9th Jul 2019 7:11am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
you can try cleaning the it with brake cleaner I had a Peugeot some years ago and it worked on it
Post #780792 9th Jul 2019 11:46am
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I did it a few times with my last Avensis, the EGR valve was a known problem on them but thankfully the workshop manager of my Toyota Dealership told me to clean it instead of paying out about £300 for a new one.
I then used to remove and clean it every 20,000 miles just to be on the safe side.
Post #780938 10th Jul 2019 10:33am
MartinK
just been doing some research as mine's nit making the usual sound (chucka chucka chucka) on switch off. It'ds still working but not as well as normal.
Some other useful posts on here
https://www.defender2.net/forum/topic40101.html
The Transit parts seem to be transferable too, but no cost advantage I can see... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #780940 10th Jul 2019 10:48am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Just replaced mine even though it's turned off via the ECU. I didn't realise it was slightly open due to the driven cog on the electric motor shearing off. No more black smoke and my flat spot has disappeared too. Should hove done it years ago. 130 crew cab
98 V8 Disco
Post #781025 10th Jul 2019 9:40pm
Naks
mine's been turned off by the BAS remap since 2010, but after standing for 7 months, there is now a screeching noise when I switch off the engine.
the indie reckons it's the EGR, so maybe it's time to remove the hardware as well. --
Post #781065 11th Jul 2019 9:17am
I'd be very surprised if the screeching noise is the EGR.
You could try simply unplugging the EGR valve and seeing if it still happens.
Post #781067 11th Jul 2019 9:20am
Naks
that's what I thought, to me it sounded more like an electronic/electrical screech, but the indie was adamant it's the EGR... --
Post #781071 11th Jul 2019 9:28am
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
My one has started being very noisy on its cleaning cycle. Just started at exactly 75000 miles.
Is this an option? Well, won’t let me put pic on. But it is a ego simulator kit. Anyone tried one?
Kev
Post #781451 14th Jul 2019 2:24pm
MartinK
One of these?
https://www.ebay.co.uk/itm/10-EGR-AGR-Simu...SwrhBZAjRW Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #781524 15th Jul 2019 7:48am
Kevzeboy
That’s the one.
Post #781628 15th Jul 2019 9:59pm
Roy5695
On shutdown the EGR valve does a cleaning cycle. Usually left active even if the actual motoring if the egr is disabled during driving.
When the gears get jammed the motor still try’s to do this cleaning cycle. Hence the screech you hear. I’d almost guarantee it being your EGR. [/list] 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #781640 15th Jul 2019 10:59pm
Some months ago, when driving along with the window open, I heard a strange squeak/screech. Didn't happen very often initially, but the frequency increased, typically when changing up from first to second. I also noticed a dead spot appearing at the same time, especially when the engine was warm. Over the last few weeks it got progressively worse and so yesterday I had the valve renewed. What a difference! It's like a different vehicle with smoother and freer acceleration. I can only assume that the original valve had been sticking open but I've retrieved it and will carry out a post mortem when I get five minutes.
Incidentally, I did consider having it mapped shut but my conscience got the better of me. Darren
Post #782288 20th Jul 2019 10:00pm
