Home > Maintenance & Modifications > Safety Devices Cage Accessory
Not_Given
United Kingdom 2011 Defender 110 Puma 2.4 SW Orkney Grey
I’m about to have an SD external cage fitted to my 110 and was perusing the SD website when I stumbled upon these:
https://shop.safetydevices.com/collections...pgrade-kit
Anybody have experience with whether they’re worth having? Seems a lot of money for some rubber gaskets, especially as the cages aren’t cheap in the first place! Seems the stock gaskets are ‘foam’. However, I will stump up the extra £50 if the consensus is positive.
I would appreciate any feedback from those with knowledge/experience of these.
NG
Post #781346 13th Jul 2019 3:50pm
Greyman110
I have these on my cage but it was fitted by the previous owner. I can say they look tidy but apart from that I'm not much help Laughing
Post #781355 13th Jul 2019 5:32pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I’d fit them. Land Rover fitted them to my Black and I think it would look a bit unfinished without them, although yes, it does seem rather expensive for a few bits of rubber. 2002 110 td5
Post #781356 13th Jul 2019 5:43pm
bankz5152
Re: Safety Devices Cage Accessory
NG
My cage came with them from standard. Instagram @defender_ventures
Empire Tuning - Agent
Post #781362 13th Jul 2019 6:05pm
V8GPC
ignore
Post #781518 15th Jul 2019 7:18am
Matt110
They come with the cage, when I checked with SD when they fitted mine they said they were only on the website as replacements for existing... I had the same concern.
By all means check with them when your cage is ordered but should be ok.
They're part of the cage to body sealing mechanism. You could do them with sealer but using these and a small amount of sealer is better.
Post #781520 15th Jul 2019 7:23am
Not_Given
Thanks for the advice, everyone. I’ll double check with the fitter..
NG
Post #781527 15th Jul 2019 8:00am
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
They came with mine too originally.
Post #781534 15th Jul 2019 8:56am
Not_Given
Thread update for those who care:
Cage supplied and fitted with a full set of grommets! Clearly, replacements are available if/when the rubber gives up.
NG
Post #816417 22nd Feb 2020 4:12pm
markb110
When I fitted my SD cage the front legs had the rubber seal but the four for the tub were a neoprene foam.
As the fit was so tight the neoprene seals want to fold under the cage feet and were a real Pita.
Go with the rubber ones if SD still don't supply them as standard.
Post #816421 22nd Feb 2020 4:47pm
