Home > Puma (Tdci) > Alive Comfort Springs - not like expected. |
Fred95 Member Since: 23 Oct 2011 Location: Gruenwald Posts: 9 |
Agree. This is definitely, what I would expect from a spring, which is called „standard height“.
Unfortunately Alive does not comment on this fact, when I asked them. Neither me, nor my workshop can invest in time and money to rectify a problem for the vendor. So I decided, to remove them and send them back. |
27th Jun 2019 8:45pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
Hi there. Mine had done 60k. It looks pretty level with the springs fitted and drive superb, much better than before. Not a great pic, but the only one I have: Click image to enlarge |
27th Jun 2019 8:55pm |
agner Member Since: 28 Jul 2014 Location: jakarta Posts: 3 |
Hi, i have just installed fox shocks and alive comfort standard height + ARB.
the rear seems to be lowered from stock around 2 cm. also the front spring is longer than the stock springs. satisfied with the improvement but dont expect much its still a defender. also i wanted to try to raise the rear by installing anr2938 spring isolator on the rear spring (2 pcs top and bottom) to bring the rear height back to normal. stock front Click image to enlarge stock rear Click image to enlarge front eibach standard height Click image to enlarge rear eibach standard height Click image to enlarge normal suspension Click image to enlarge alive tuning fox suspension kit Click image to enlarge |
9th Mar 2021 6:34pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Just to resurect this thread does anybody have the measurements of the alive standard height comfort springs as ive had mine laying in a box for a while and i dont want to go to the expense of getting them fitted if they are to long?Thanks in advance.
9th Mar 2021 6:55pm |
The post immediately above yours has comparative measurements in. Darren
10th Mar 2021 9:38am |
Thanks but I was hoping somebody might be just about to fit alive springs
And. Would measure the height prior to putting them on their truck do do I could check mine before paying someone to fit them. |
10th Mar 2021 2:46pm |
So you want to check that your springs match somebody else's of the same spec.? Do you think there's something wrong with them? Darren
10th Mar 2021 3:34pm |
The original post was about the size difference with the alive springs and the original ones.......my alive springs are in a box and by eyeballing them they don't look like the op picture so I was hoping somebody has just received a set of alive springs so they can measure them and see if they match my set...there are s few posts on here describing how alive have sent the wrong or faulty springs so I was posting a long shot to confirm sizes of the alive springs that might in the in the long run save me a few quid in fitting costs ...
10th Mar 2021 4:29pm |
Ahh, I'm with you now. Darren
10th Mar 2021 5:15pm |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 185 |
I would have thought that the springs should be changed with uprated dampers at the same time.
10th Mar 2021 5:29pm |
rear stock vs standard height
Click image to enlarge front stock vs standard height Click image to enlarge they have code written in the spring i suggest to contact alive tuning to check |
10th Mar 2021 7:29pm |
10th Mar 2021 7:39pm |
Benrlelliott Member Since: 29 Dec 2020 Location: London Posts: 25 |
I'm having the same effect with all new fox shocks, isolators and genuine springs. Old hardware was shot (100k miles) and replaced, hence considering how much the old rake / stance was a function of old equipment vs. is there anything to be concerned about here...?
There was considerable lift after install (sorry no measurements), far above the extra of the isolators, which leads me further to believe it's a result of new vs old. |
30th Jul 2021 7:40am |
johnnyha Member Since: 08 May 2019 Location: London Posts: 40 |
FWIW I've recently fitted the -1" comfort springs with Bilstein shocks. No issues and rides well. The comms from Alive were excellent.
Photos to follow |
31st Jul 2021 8:25am |
