Home > Maintenance & Modifications > Swivel Seals Upgrade, should I do bearings too?
Grenadier
I have a leaking swivel seal and will be replacing the pair. Should I do the bearings too, given I'll be taking everything apart? 60km vehicle, with (as far as I know) original bearings. If so, what brand? Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #775144 27th May 2019 7:55am
dorsetsmith
Check condition of the swivel ball for pitting, this main that cores seal fail
Should I do the bearings too, yes
606666 TIMKEN lower bearings
Swivel Pin - Upper - Less ABS TAR100040 LRJ
Swivel Pin - Upper - with ABS TAR100050 LRJ
Post #775150 27th May 2019 8:27am
hank
They are not bank breaking so may as well. I would recommend Timken for quality aftermarket.
Although I can understand why people wouldn't bother given that seals are penny parts whereas quality bearings are maybe £25 - £30 each for aftermarket or £45 - £50 each for genuine so it turns a few quid job in to maybe a couple of hundred
Could get the bearings in then strip/inspect the condition. Can always return them > 110 XS Double Cab
> Instagram @simonlanemind
Post #775151 27th May 2019 8:33am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Another vote to say yes and to go for Timkin bearings. If you’re stripping everything down it’s hardly any extra work. Also worth checking brakes for wear.
Post #775153 27th May 2019 9:10am
Grenadier
Thank you all. New bearings (Timken is what I was looking at) it is.
Will also check for pitting, fingers crossed seem to be ok from external inspection. New pads were fitted under 2000k ago, so all good there.
Cheers Monsieur Le Grenadier
Post #775168 27th May 2019 10:34am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Also Worth fitting Stainless Steel Swivel Oil Seal retainers while you're there. Stiffer than standard so helps stop Oil seal leaks.
RRY500180SS
https://www.lrdirect.com/RRY500180SS-Swive..._https=yes
Post #775210 27th May 2019 7:39pm
Grenadier
Thanks EpicTrail, good thinking. Will definitely order these. Thumbs Up Monsieur Le Grenadier
Post #775252 28th May 2019 6:59am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
What locking nut system will you use? If the newer type you will need to measure and adjust the end float when putting everything back again.
Post #775261 28th May 2019 8:26am
oneten110
For goodness sake don't buy the bearings from any form of car parts supplier. Go to a bearing specialist, they will charge you far less than any land rover dealer or specialist, same for the seals. It is not a Defender, it is a One_Ten
Post #775454 29th May 2019 7:49pm
